6speed Technical Information forum This area is intended for members to post their technical questions that will be answered by anonymous experts posting as 411. Members may provide knowledge but sponsors are asked to not post in this forum.
Whirring noise on acceleration
Old 02-05-2016, 04:02 PM
MotoJB's Avatar
MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !
Hey gents,
My 2001 996 TT is making a pronounced whirring/humming noise while under acceleration...a noise that seems to change (increase/decrease in pitch) depending upon RPM.
It doesn't make any such noise at idle, nor does it seem to make any noise when pushing in the clutch (coasting at speed) and/or while revving the engine.
Any idea's what this might be? Concerning.
Thanks.
Old 02-06-2016, 01:03 PM
MotoJB's Avatar
Ok, update...pulled the radio/speaker fuses and as expected, the sound is still there.
A bit more clarification - seems the noise is non existent when driving around town. I only seem to hear it when I'm on the freeway (at speeds where I'm using 4th - 6th gears).
Cruising along in 5th or 6th gear on the freeway, it seems to be the loudest between 2200 and 3000 rpm's. Again, every time I step on the gas ever so slightly (even when not in boost - so not a symptom of the Turbos).
It's just a whirring, whining noise that changes in pitch linearly with RPM's.
Old 02-06-2016, 01:41 PM
MotoJB's Avatar
Here are some videos where I tried to capture the noise. Pretty audible in these (poorly shot) videos. Thanks for your continued help/input!
Old 02-06-2016, 03:51 PM
Macster's Avatar
Well, my first impression is it is an exhaust leak.
However, I could imagine -- I have a pretty good imagination though -- under throttle the engine's twisting (or the transmission is twisting) (due to a failed engine or transmission mount) and the engine or part of it or the transmission or part of it is contacting something.
Old 02-06-2016, 04:16 PM
MotoJB's Avatar
Thanks...more potential things to investigate! Appreciated Macster.
Old 03-03-2016, 10:31 PM
MotoJB's Avatar
Well, it's official. My transmission is toast.
How foolish it was to trust Zuluracerx and his "fresh" PPI from BBI.
With an extremely loud kline 3" decat exhaust and the stereo, I didn't hear the transmission noises until after I bought the thing. The noises only became evident with no stereo and after a bit more time, while on the freeway. Couldn't hear it around town.
Moral of the story? Don't trust anyone (no matter how well they check out nor what they say) and get your own PPI done. (DUH)
In the end, people who say they'll "stand by the car should you have any problems"...don't. Instead they accuse you of ruining the transmission by "launching the car", etc. Not the case. I cautiously drove the thing home in 6th gear, to and from the grocery store, to and from cars and coffee (in town) and to and from the Porsche shop to diagnose the noises. That's it. Anyhow, my fault for buying without getting it thoroughly checked.
Anyhow, I'll be happy with the car once the transmission is rebuilt but damn, what a HUGE unexpected expense right out of the gate. Big lesson learned.
Good thing my wife is taking it so well.
Old 03-05-2016, 10:54 AM
Macster's Avatar
Too bad it turned out to be the transmission. These are generally pretty durable.
Thanks for the update.
Old 03-05-2016, 11:16 AM
MotoJB's Avatar
Yep...sucks. Thanks Macster.
Old 04-13-2016, 01:34 PM
MotoJB's Avatar
Here's the latest...input and suggestions welcomed!
"My tech is just wrapping it up.
I’ve heard the main components worn out are the pinion bearings, bearing retaining plate, 2nd gear, 1st/2nd shift sleeve, 3rd/4th fork – we’ll also recommend the synchros.
Someone has been in this box before, 5th gear has been replaced with a stock 993 gear presumably BC the original was worn out. There are steel synchros in 3rd-5th gear positions also. Do you think you’ll want new steel ones again or brass ones for half the cost? Your ring and pinion has some uneven wear but is okay to reuse but not with TON of power.
At a glance this will be much cheaper than buying our gearbox but it’s still going to be an expensive service.
Estimate to follow."
Old 04-16-2016, 07:54 AM
cjv's Avatar
cjv
cjv is offline
Moderator
I would go with the steel ones as the labor is the big cost and you have to do it either way.
Old 04-16-2016, 09:14 AM
MotoJB's Avatar
Yeah, I went steel...but the steel synchros about double the price over brass. Expensive. As is converting to GT2 spec. That seems to add about another $2k to the job.
Old 04-16-2016, 09:47 AM
'02996ttx50's Avatar
bummer. zuluraxerx sold you this without disclosing that the trans was toast and about to go? hard time imagining he didn't "know" if so thats really lousy.
cant help you wi any advice on the box as that should be wholly dependent upon your eventual goals for the car. obviously if you're gonna ( down the road? ) "build it out"? then do all ya can now, different ratios steel vs brass g2 bits etc. as all i had to do was replace the pinion bearing and i was in and out as all else looked new ( at 120k + miles )..
sorry you hadda do all this so close to having just bought the car. that had to be unanticipated. ouch.
Old 04-16-2016, 10:19 AM
MotoJB's Avatar
Ahhh yep, that's pretty much how I see it...someone that has "owned 25 Porsche's" and has a GT2 race car, you'd think he knew. Also, his "fresh PPI" from BBI upon careful re-review sure seems fishy - dates and data seem to be doctored up to me. His CARma now, not mine. It'll come back.
Yes, painful. When all is said and done, I could have almost had a nice 997 TT for the money dumped into this one. Oh well.
Anyhow, I'm going to the GT2 spec with all steel bits...expensive but trying to do it right.
Thoughts on the GT2 slave mod?
Thanks again for your help man.
Old 07-30-2016, 09:30 AM
JimHJr's Avatar
JimHJr is an unknown quantity at this point
Just came across this. Hope you got it all back together and are enjoying the car now.
Old 08-05-2016, 11:14 AM
MotoJB's Avatar
Thanks Jim...after time and a lot of dough, it's back together and doing well.
Sucks I had to spend that much money on the trans out of the gate, that could have gone into suspension and power mods.
Oh well. I got my white 996tt unicorn...and lessons learned.
george_b
06-10-2020 12:46 AM
nitrorocket
04-20-2016 04:35 PM
epik high
02-04-2016 06:38 AM
Porsche_Shiftin04
02-01-2016 06:58 PM
Bleen
01-30-2016 11:56 PM
Quick Reply: Whirring noise on acceleration
