924/944/951/968
1990 944 S2 Cab HELP!
Old 08-29-2016, 08:35 AM
Left Handy's Avatar
Left Handy is an unknown quantity at this point
Exclamation 1990 944 S2 Cab HELP!
I was driving home when she started to sputter, then when I pressed the gas it dropped and I was hard pressed to get 15 mph out of her. I finally got to a safe place where I could stop. I let her rest a bit and I was able to re-start. She was fine again for a little bit, when the symptoms came back. I was barely able to get her home. Now she will not stay started. She turns over and acts normal for a second and then shuts off.
My first thought was the fuel relay DME. Got a new one and replaced, no change.
Next I pulled the fuel filter and found it was the original dated 4/14/1989.
I've decided to go ahead and replace the pump as well while I have everything apart.
Any other suggestions? What else should I go ahead and change while I'm at it?
Thanks in advance, Chris
Old 08-29-2016, 09:27 AM
Cannonball996's Avatar
Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !
hows your voltage? I have similar symptoms when an alternator failed
Old 08-30-2016, 07:49 PM
djantlive's Avatar
I would check plugs, coils as well.
zuman
04-02-2016 10:37 AM
luting_chen
10-09-2003 12:58 PM
Chris Y.
09-12-2003 06:35 PM
mumanoff
08-19-2003 06:43 PM
Quick Reply: 1990 944 S2 Cab HELP!
