6speedonline.com Forums
User CP
Visit our Sponsors
Go Back   6speedonline.com Forums > Porsche (Past) > 944 Turbo & S
Reply
Thread Tools Rate Thread Display Modes
Old 05-03-2008, 11:07 AM
labor time?
how much time do you guys think it would take to fix oil leaks in front and rear of cam area, crank and oil pan? The car is a 86- 951
Trying to figure in my cost of labor on this one
Sponsored Links
This ad is not displayed to registered members.
Register your free account today and become a member on 6SpeedOnline!
Old 05-07-2008, 07:52 PM
IAPorscheDoc's Avatar
If the main cam gasket needs to be repaired, then figure about 5-6 hours for a shop to pull the box, reseal it on the bench, and replace. If the main gasket is ok, and the front and rear seals need to be replaced, figure about 3-4 hours. Front crank seal is another 2 2-3 hours on top of the cam seal replacement (timing belt all needs to come off for that, so it is a good time to replace belts, rollers, and even the waterpump since you will be right there). Oil pan gasket/rod bearings on an 951 is about 12 hours IIRC. The intake has to come off, the crossover pipe, lower crossmember, etc. You will want to do the rod bearings while you are in there.
To make it easy, typically I charge about 11 hours for waterpump, belts, rollers, all front engine seals (upper balance shaft, lower balance shaft, crank seal), and the cam seals.
Unfortunately nothing crosses over between the oil pan gasket job and the front seals job.
Doc Wilen
86 951....not stock
Old 05-07-2008, 08:22 PM
thanks, I am having the following done:
- everything you mentioned above plus
-electric fans replaced.
-odometer repaired as it does not work
-alignment
-the entire exhaust system replaced with all new pieces from downpipe to tail. I already had those parts so it is labor only.
The total cost is $2800 which floored me but if the part you quoted was 12 hours, there is probably another 10 hours worth of work there.
Old 06-25-2008, 01:46 PM
I wouldn't be suprised by that estimate. My local Porsche dealer is over $100 an hour now.
87 951 04 944 Fest Grand Champ Car
87 928 S4 Cassirot
87 928 S4 Black/Tan
Old 06-25-2008, 04:36 PM
sounds about right. i do all my own work now.
Old 07-16-2008, 10:21 PM
If you local in SoCal I know a guy who does em really cheap. It's alot of work to do the oil pan, put it this way...after having done it once I will never do it again myself too much headache usually they charge around 600-800 to do it but my guy does it cheaper so its worth it...atleast it is to me. the gasket is only 41 dollars lol the rest is labor ).
I would try to get it done as low as possible, but be careful cuz they are kinda picky cars
Onekon
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
