6speedonline.com Forums
User CP
Visit our Sponsors
Go Back   6speedonline.com Forums > Porsche (Past) > 944 Turbo & S
Reply
Thread Tools Rate Thread Display Modes
Old 05-11-2008, 03:08 PM
CarbotechDanny's Avatar
Carbotech brake pads...
Hello 6speed members,
My name is Danny Puskar and I am from Carbotech Performance Brakes. Carbotech has recently become a sponsor on 6speedonline.com. I have been a member and a fan of this forum for quite a while now, and would love nothing more than to support this forum when possible.
Also, there isn't a brake pad or brake shoe that Carbotech can't make. We can build any and all brake pads with your choice of our compounds that you need for your application.
If you’re not familiar with Carbotech then here is some information that separates us from everybody else. If you want more information then please visit our website at www.ctbrakes.com
Carbotech Performance Brakes™ began 15 years ago. In the beginning we thought like everybody else and made brake compounds out of carbon & iron. The problem with carbon & iron is that when it heats up it forms carbide. Carbide is used in cutting tools, so imagine what that does to your rotors. Along with the fact that those compounds tear up rotors, they also produce very corrosive brake dust. While our competition stills uses carbon & iron as the main ingredients in their compounds, Carbotech™ started an entire new philosophy over seven years ago.
Carbotech Performance Brakes™, a world leader in Ceramic friction materials™. It was over seven years ago that Carbotech™ started building brake pads out of Ceramic, Kevlar, and Carbon for street, autocross and racing applications. Carbotech™ is the only brake pad manufacturer in the world with a complete line of Ceramic compounds for street, autocross, and track use.
Carbotech-Ceramic™ compounds are known for their unsurpassed release & modulation, while maintaining very consistent torque control characteristics. Carbotech™brake pads are extremely rotor friendly and contain 100% non-corrosive brake dust, that’s something that has been unmatched by any other brake pad in the industry.
Our competitor’s brake pads perform like an “on/off” switch. Brake pads that perform like an "on/off" switch are upsetting the balance of the car by violently throwing all that weight forward (not to mention that you don't get any modulation with an "on/off" type of brake pad). You don't realize how much it upsets your car until you have tried Carbotech™ brake pads.
Carbotech™ has a seven year head start on the competition when it comes to our great philosophy on modulation & release, rotor friendliness, non-corrosive dust, and an unmatched consistent bite/torque control.
Carbotech™ uses advanced friction technology to perfect all of our compounds for the street & track. Research & Development (R&D) is not just a company philosophy; it’s a way of life at Carbotech. We strive in constantly improving our existing compounds as new technologies and materials come to market.
Carbotech Performance Brakes™ allows drivers to Go Deep™ into the corners and out brake the competition. Carbotech™ has won multiple pro races, national championships, and rally races all over the world. Our high performance street compound is our 1521™. The next in our lineup is our Autocross compound, AX6™.
Our race compounds start with the letters "XP™" then they are followed by a number. The first number is 8 (XP8™, then XP10, XP12, and XP16), and as you go up in numbers the initial bite gets much stronger, higher fade resistance, higher torque, and an increase in the temperature range. On that same note, as you go up in our compound numbers you will get slightly faster wear rate on the pads and a little more aggressive on the rotors. That being said, even our more rotor aggressive compounds are still much more rotor friendly then our competitions compounds.
For more information please visit our website at ctbrakes.com or give us a call at 877-899-5024.
Thank You for your time,
Danny Puskar
4031 Dearborn Place N.W.
Concord, NC 28027
877-899-5024
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
6speed discount code: 6SCT08
Please use this code when ordering Carbotech brake pads to recieve your discount.
Sponsored Links
This ad is not displayed to registered members.
Register your free account today and become a member on 6SpeedOnline!
Old 07-26-2008, 12:26 PM
hi danny, thanks for the info. i'm curious how carbotech pads perform compared to porterfield r4 or r4s carbon-kevlar pads;
http://www.porterfield-brakes.com/ma...hp?manufId=228
http://www.porterfield-brakes.com/ma...hp?manufId=231
what's especially interesting is that carbotech claims to be;
while porterfield claims to be;
the most rotor friendly racing brake pad material ever.
they can't both be right, can they?
Old 07-28-2008, 10:44 AM
Hi Nize,
That's a great question. The biggest difference will be in the modulation and trail braking ability you will get from the Carbotech's. The R4 is most comparable to our XP10 compound. XP10 will give you more bite and torque then the R4. XP10 has a greater temperature range and will require as much heat to start working properly. XP10 will be a lot more rotor friendly as well.
The R4S is most comparable to our 1521 compound. 1521 will give you better performance, longer pad life, easier on the rotors, and still produces 100% non-corrosive brake dust.
Danny Puskar
Concord, NC 28027
877-899-5024
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
