Go Back   6speedonline.com Forums > Porsche (Past) > 944 Turbo & S
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 04-10-2009, 02:48 PM #1
Mig17 is on a distinguished road
1990 951S with a need of some upgrades...
Good evening
I own a 1990 951 (late model with 968 wing, Desing 90's, etc.), and I'm very happy and satisfied with the car, but I feel the suspension is too soft and I'm not confortable in fast turns, etc.
The car has lots of power, and I'm not planning major engine upgrades for now. The main reason because I want to upgrade the suspension is that I think the car runs more that it handles. For example, I feel safer with my old 924 than with the 951.
Any ideas about upgrading the ride? Sway bars, suspension, rods, etc. I'm completely a newbie about this....
Thanks in advance.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
Porsche 951S '90, Porsche 924 2.0 '85
Old 04-13-2009, 12:43 PM #2
FLpaindoc's Avatar
FLpaindoc will become famous soon enoughFLpaindoc will become famous soon enough
How many miles on the car?
'04 996 Turbo cab., X50,Triple black
'06 Cayenne titanium
'88 944 Turbo S Silver Rose (sold Dec. 2009)
'99 996 MO30,Mirage metalic, B&M short shifter, Evo intake, TUBI (sold sep 2009)
Old 04-14-2009, 12:37 AM #3
Quote:
Originally Posted by flpaindoc View Post
how many miles on the car?
55.000.
Old 04-14-2009, 06:47 AM #4
FLpaindoc's Avatar
do you have an adjustable suspension? I hava '88 turboS and I can manually adjust mine.
Old 04-16-2009, 07:29 PM #5
aixgelo78 is on a distinguished road
he should have the yellow adjustable konis....but there are tons of thing you can do to upgrade your suspension
Old 04-16-2009, 07:30 PM #6
check rennlist...there are tons of info there
Old 04-22-2009, 02:03 PM #7
GrantM951 is on a distinguished road
Do you have the M030 F/R swaybars, 30mm front, 19mm rear, with delrin bushings?
Grant
89 951
Old 04-27-2009, 03:04 PM #8
kirk911tt's Avatar
kirk911tt will become famous soon enoughkirk911tt will become famous soon enough
If turns are what bothers you I agree with Grant, Ihave 2 951's in my collection one is mild and one is wild. Sway bars will keep the car from leaning, but if oversteer is what is scaring you then soften the front shocks on your adjustable koni's and you will increase understeer. The flat adjuster on top your shocks should be turned counter clockwise until it stops at full stop and then adjust them (clockwise)harder as you wish.
Peter
01 996 tt
fvd stage 2
titan motorsports diverters
fidanza lwfw
stage 3 spec clutch
Old 08-09-2009, 09:48 PM #9
spooled951 is on a distinguished road
sways can be a major improvemnt
Old 08-09-2009, 10:47 PM #10
DHinkle's Avatar
DHinkle has much to be proud ofDHinkle has much to be proud ofDHinkle has much to be proud ofDHinkle has much to be proud ofDHinkle has much to be proud ofDHinkle has much to be proud ofDHinkle has much to be proud ofDHinkle has much to be proud ofDHinkle has much to be proud ofDHinkle has much to be proud of
Contact Karl Poeltl of Racer's Edge (865-862-5270). He designs suspension upgrades for 944's and is the fastest 944 racer in the U.S. With the proper set up, you will embarass many of your fellow 6speeders for a fraction of what they have invested in their car.
Old 08-09-2009, 11:24 PM #11
LUISGT3's Avatar
LUISGT3 has a reputation beyond reputeLUISGT3 has a reputation beyond reputeLUISGT3 has a reputation beyond reputeLUISGT3 has a reputation beyond reputeLUISGT3 has a reputation beyond reputeLUISGT3 has a reputation beyond reputeLUISGT3 has a reputation beyond reputeLUISGT3 has a reputation beyond reputeLUISGT3 has a reputation beyond reputeLUISGT3 has a reputation beyond reputeLUISGT3 has a reputation beyond repute
Quote:
+1 Karl hooked me up with suspension for my S2 track car over 10 years ago.
Old 08-15-2009, 08:21 PM #12
cibergypsy's Avatar
cibergypsy will become famous soon enoughcibergypsy will become famous soon enough
On my '88 Turbo I had Koni adjustables, Weltmeister sway bars, Racer's Edge bushings for the front control arms, Weltmeister camber truss and that was it as far as suspension was concerned. Very minor stuff but the car ran beautifully at Roebling Road but was still a great street car. I had 17" wheels wider than the stock ones but I can't recall their exact width. This was my DD until I got an '87 Carrera Coupé to replace it... deep inside, though, I miss the 951 a lot.
When it came to brakes, I just put some Weltmeister stainless steel braided lines, cross drilled rotors, Pagid brake pads and that was about it too. The car's brakes never let me down in track driving.
The car had a factory limited slip. On the engine side, I just had a Lindsey Racing intercooler (the biggest one that was able to be mounted under the stock nose panel), changed ALL the vacuum lines to blue silicone lines with brass fittings from Lindsey Racing, the Lindsey Racing boost enhancer, billet blow-off valve, Autothority chip, K&N filter on the stock air box, adjustable fuel pressure regulator, B&B cat back exhaust with stock headers. I also had the stock turbocharger rebuilt and everything else was stock. Believe it or not, it was as fast from 0 to 100mph as my 2004 996 C4S! What a great car! I may be getting a Turbo S this time.
I have looked at the dry sump setup from Lindsey Racing but, since I don't have a 951 anymore, I haven't called them to enquire as to where would the oil tank be mounted on the car. I definitely wouldn't want it or any oil lines inside the car.
1987 911 Carrera
2006 Carrera S X51
Past: 1983 944, 1988 944 Turbo, 1994 968 Coupé, 1984 911 Targa, 1986 Ferrari 328 GTS, 2004 996 C4S.
Reply
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
