KA Motorsort 991 Turbo/S Sport exhaust Kit
$3500.00
Deep, Rich and Low Flat 6 turbo tone, without the negative drawback of drone.
- + 25 Hp & + 19 torque
- 200 Cell high flow, tri metal german HJS “HD” high durability matrix sports catalysts.
- 2 3/4″ tubing (70mm) for max. power across the rpm range.
- Weighs 37 lbs. (16.78 Kg).
- T 316 stainless steel for improved durability over T 304.
- “Aeroquip” cone style catalytic connection design to prevent exhaust leaks.
- Includes “Aeroquip” quick release clamps.
- Made in Germany.
- Modular design for 100 cell, 200 cell or bypass use.
- Intoxicating growl at idle, partial throttle and wide open throttle.
Also available are our Sport Headers
$1599.00
+ 16 Hp & + 15 torque
- Weighs 11 lbs. (5,3 Kg)
- Includes specially designed expansion joint that resists cracking on cylinders 3 and 4.
- Made in Germany.
- More pronounced spooling sound at idle, partial throttle and wide open throttle.
- ECU programming (Software) is NOT necessary.
- Made in Germany.
$1599.00
- Made in Germany.
