Will 19" 997 Turbo wheels fit on a 991 Turbo?
I was wondering if the stock 19" Turbo wheels from a 2009 997.1 turbo
will fit on a 2014 991 Turbo? Neither car has PCCBs.
So, what is the verdict?
OK -
So you are saying the wheel offsets are compatible
and the specific tires required by the two wheels sizes are
obviously different and the outer tire diameter is smaller on the 19"
wheels.
Are there any issues other than that the speedometer on the
2014 911 Turbo would read too a bit high on the 2014?
wheels.
I'm pretty sure that they won't. The dust shields behind the rotor are so large that the 19's won't clear. If I thought 19's would fit, I wouldn't be selling my 19 inch BBS winter wheel package that I had on my C2S last winter.
19" on the 991 TurboS
I'm sure they will not work. The 991 turbo S discs are 45cm in diameter.
Then the front callipers are 9cm high. When I look at the clearance on my car with the 20" wheels there's only possible 2cm from the wheel. With the calliper & rotor set up added up it's amazing the 20" wheels fit. 19 forget it. Even if you used a spacer the brakes would likely be damaged if you got them on there somehow.
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
08-18-2015 03:41 PM
PelicanParts.com
997 Vendor Classifieds
08-18-2015 03:39 PM
