21" HRE P101s?
21" HRE P101s?
Ok....getting serious about getting a set of P101s for my TTS. If I do it it will be in the brushed dark clear finish. Center lock type wheels with TPMS.
Talked with Wheels Boutique, and I can go with stock 20" replacement sizes and use my existing tires (P-Zeros), or go for the badass HRE setup, which is Front 21 x 9.5 wheel with P-Zero 255/30/21 and Rear 21 x 12.5 wheel with P-Zero 325/25/21.
Just FYI the stock wheels are Front 20 x 9 with 245/35/20 tires and Rear 20 x 11.5 with 305/30/20 tires.
This 21" setup has no rubbing problems, and is a direct replacement without pushing the tires past the fenders. A downside is that Michelin PSS tires are not available in the 21" size, so I am limited to P-Zeros or Continental. Nothing wrong with the Pirellis, however.
What do you guys think? Go for the stock replacements or get the badass setup? Below is a pic of a GT Silver TTS coupe, just like mine, with the 21" setup. Fills out the wheel wells nicely.
Opinions?
Opinions?
Ok....getting serious about getting a set of P101s for my TTS. If I do it it will be in the brushed dark clear finish. Center lock type wheels with TPMS. Talked with Wheels Boutique, and I can go with stock 20" replacement sizes and use my existing tires (P-Zeros), or go for the badass HRE setup, which is Front 21 x 9.5 wheel with P-Zero 255/30/21 and Rear 21 x 12.5 wheel with P-Zero 325/25/21. Just FYI the stock wheels are Front 20 x 9 with 245/35/20 tires and Rear 20 x 11.5 with 305/30/20 tires. This 21" setup has no rubbing problems, and is a direct replacement without pushing the tires past the fenders. A downside is that Michelin PSS tires are not available in the 21" size, so I am limited to P-Zeros or Continental. Nothing wrong with the Pirellis, however. What do you guys think? Go for the stock replacements or get the badass setup? Below is a pic of a GT Silver TTS coupe, just like mine, with the 21" setup. Fills out the wheel wells nicely. Opinions?
If you're gonna be a baller, be a BALLER!!
21" for sure. I have the exact setup you're looking at and I absolutely love it. Makes a stock-wheel car look bland.
Sorry to all you stockers out there....!
Boldgt
03-23-2016 11:07 AM
miken168
10-06-2015 09:21 AM
