If you want to default to sport setting at startup use this
I ran across this neat little device (memory module) so had to get one asap..works the charm..now my car always starts in sport as I left it at shut down..simple install...btw on our cars there's no need to remove console side bolsters..just grab center button control panel and firmly pull off of console..it's held in place with clips..a little easier to remove if you pry with a plastic tool..
http://t-design9.com/
It will work on 981s too since he had one to work with. I had one of the early versions with the electronics installed in the existing switch module and I had to send him mine. The car was still driveable and there was a quick turnaround. Vlad might have a version for other current cars but best to contact him to be sure. Definitely worthwhile.
However I had a few questions:
1) Where did you mount it? I mounted it to the metal bracket on the side.
2) I found the connectors don't have clips to make sure they don't slip out. So it is held in place by tension. To me this feels pretty poor design. Do you think I should tape the connectors?
1) Gheeze don't recall as car is snow parked right now but I think I tie-wrapped it in place
2) if i recall I had an issue engaging the connector and had to slightly modify but mine fit together very tightly..tape or heat shrink if you're concerned but mine has been fool proof..and so nice to have the car default to sport...I'd say a must have for 991.1 owners
Ah, but from what i see not yet for the 17' 991.2 Turbo S with the steering wheel dial. Bummer.
According to the website it does http://t-design9.com/memory_module.html
When I see all the tech things in the newer cars, makes my 997.1 feel so old.
I do hate the fact I have to hit the sport button each time I'm about to drive the car. =(
Maybe a used 991 is in the cards down the road. If not, I'm still happy with my 997.
Love it.
Installed today on my 991.2 (2017) TT Cab with the wheel ****.
Impressions
5-minute installation - super easy
Deactivated the auto off (Hate this feature) - car never turns off by its self.
Does not stay in sport mode all the time (I knew this when I purchased it).
I also recommend a SmartTop if you have a cab. I have installed it on my last 3 TT's cabs and LOVE it.
Impressions
Just received my first shipment of T-Design9 products for the shop!
High quality cell phone mounts, sunglass holders and memory modules
Installed the memory module on my 991.1 TT shop car and confirmed that it holds "Sport" mode on even after shut off!! Operates as per design
