Kline, Europipe, Akra...sound differences at idle?
From research on this forum, it appears that these are all top choices so while I wait for my '17 TT build, I continue to struggle with what I'm going to use. When folks talk about the 'vacuum cleaner' sound from the stock system (which I know well from three previous 997.1 and 997.2 Turbos I've owned), it is most pronounced at idle which leads to my question. All of the aftermarket systems I mentioned seemed to have eliminated any annoying drone at driving speeds, so if I am correct they are equal in that aspect. I typically see the comment that at idle, some or all of these are 'not much different than stock at idle', but I honestly want a system that is indeed more aggressive at idle - but not something annoying when underway. Are any of these systems (of if there is another top choice I missed) noticeably different at idle than the stock system. P.S. I have no plans to change the headers and will run the hi-flow cats that come with these aftermarket systems. Thank you all.
EP is lower pitched and louder at idle than stock. It sounds very loud on coldstart up. But if you're looking for the loudest exhaust inside the cabin try the Fabspeed catalyst. I'm completely not a fan of that exhaust as I find it incredibly droney but it's probably the loudest of the major aftermarket exhausts.
I would be glad to chat with you about it and also send you tons of video anytime! With good support we can stand behind you 100# and make sure you get what makes you happiest. #GoodProblemsToHave
What about a valved system?
I bought an ipe. I like it with the valves open but it is loud and does drobe a little but you have the option to close the valves and it becomes a little louder then stock with no drone.
I use my car daily, closed valves for work and open for the weekend drives,
Best of both worlds.
OK so admittedly this is a poor video as it's from a text message attachment but it is how my car sounds now with no cats, Kline inconel headers and the TIAL turbos. The problem in the picture is the smoke coming out of the drivers side tailpipe. The conclusion is that it's oil smoke and so that has to be diagnosed and resolved before I get my car back. I am oh so close to stage 4 right now and Im about to go crazy since I haven't even seen the car in two months. This is my first exposure to it since dropping it off on Nov. 13. I think it sounds better than before for sure.
Stephen,
Here is the data:
991 Turbo idle dB measured at 1 meter distance
991 Turbo stock exhaust in normal mode: 73 dB
991 Turbo Europipe exhaust in normal mode: 78 dB
991 Turbo Europipe exhaust in sport mode: 80 dB
This is with stock headers and Europipe with 100 cell sport cats
Cheers
Here is the data:
Cheers
Stephen,
Here is the data:
Cheers
Here is the data:
Cheers
I have consistently kept the FVD exhaust but I have had several different combinations with it and all sounded different. So in my experience, there are a lot of contributing factors to the sound. Getting rid of the cats really improved the sound but putting the stock manifolds back on took some of that benefit away. The FVD headers are not equal length and produce a staccato sound and I had them on with 200 cell cats so that staccato was reduced by the cats but the car sounded better with them than with the OEM exhaust manifolds.
Now I have Kline equal length headers, no cats and the FVD exhaust and it's absolutely, IMO, the best sound the car has made yet.
The equal length headers smooth out the exhaust flow but the individual pipes add a throat to the sound that the flattened out OEM manifolds do not have. For me, the Kline headers were a good investment in sound and hopefully horsepower as well, although I don't want to get into that discussion again.
Sound ultimately is subjective. I am very pleased with the sound of my current combination of products.
Stealth, this is for you to compare and see if you really think the v8 sounds better. These are both Porsches so it's a fit comparison. To me, the flat 6 sounds much better. The v8 has secondary cat bypass and Fabspeed Exhaust with BMC filter. If we were to compare that Jag you had then I give it the thumbs up over the Porsche V8 and the BMW V8 but anyway I like the flat 6 better.
Stef - thank you for providing this information...exactly what I was looking for. I did not realize that the exhaust note/decible at idle changes based on whether it is in normal or sport mode...does it do that because in sport the idle RPM is slightly increased (now that I think of it the idle does increase from normal to sport in my 991 50th Anniversay car). Sorry to be pest about this question, but do you feel the 5 and or 7 DB increase is noticeable??
The increased dB at idle with our system is indeed noticeble but you also hear the tone improvement. As if you would switch from a transistor radio to a hifi system, so less buzz while the classic Porsche sound gets enhanced.
https://youtu.be/Ob5KqSnUEyA?t=19
https://www.youtube.com/watch?v=oH6nektZ_vM
The sound of your V8 I think sounds much better. The problem with the V8 is that you don't have a very good exhaust on that one which is why it sounds a bit boring. The Flat 6 in your case is more interesting, but the core sound is jarring. Your V8 has a nice note but a boring sound profile (not much backfire, burble or pop)
