DIY engine oil change - Porsche 911/991S
ChuckJ
Mobile 1 deals on AMZN. Check it out....
Spyder
Spyder
Did my own 10k oil change today, well 9k anyway,. The hardest part was waiting for the old oil to drain out. Thanks to all of you who provided some instruction.
One thing I will say is I purchased a replacement filter, brand name 'Wix', cause I had heard good things about the brand but as soon as I got it out of the box and compared it to the OEM filter I knew I wouldn't use it. It's about a third smaller.
So off I went to the Porsche dealer and got an OEM,,,,
lesson learned.
lesson learned.
it depends upon how long it drains. I understand that the system (including oil coolers) takes over 10 quarts.
Good to know. Thx.
Does anyone know if torque specs are the same as for 997?
997 torque specs
Filter 19 lb-ft
Drain 37 lb-ft
997 torque specs
Filter 19 lb-ft
Drain 37 lb-ft
