Base 3.4 Engine Vibration at 3300 RPM
I never received a recall notice about a muffler. Can you elaborate as to which muffler was subject to a recall? I eliminated my center muffler when I had the AWE Performance exhaust installed.
It only affected certain build dates, from 3/12 to 11/12. Here is article.
http://www.9magazine.com/2012-2013-p...t-pipe-defect/
That's what I'm afraid of, that it's some sort of cam/valve noise inside the engine which will be way more complicated to diagnose and fix.
I was wondering if it was something in the PDK box. What are those things called in a manual gearbox that make sure 2nd gear 'meshes' okay into 1st gear? I used to be able to hear that mechanical rattle type noise in my manual Cayman. I was wondering if it had something to do with that.
2012-2013 YM
Vin range ....06073-06691
.....40074-40635
.....06062-06800
.....40061-40816
The exhaust tailpipe of the rear muffler can fracture and separate.
Your dealer should know if your car is part of the recall. Mine was and it was a May 2012 build.
ChuckJ
Early 3.4s had a recall and got both mufflers under the fenders replaced.
2012-2013 YM
.....40074-40635
.....06062-06800
.....40061-40816
ChuckJ
2012-2013 YM
.....40074-40635
.....06062-06800
.....40061-40816
ChuckJ
I have been attempting to diagnose this since August. Here's what I have learned:
1) it does not occur in neutral
2) It occurs in normal, Sport & Sport +
3) It does not occur as the car is slowed in gear through 3200-3300 RPM. It occurs under acceleration load only.
4. It occurs with the spoiler extended or retracted.
I doubt that it is anything due to the exhaust, as I have an AWE performance exhaust installed. The vibration was present both before & after the installation. I have had my dealer witness the vibration. As you know it is very easy to reproduce. I got the old "operating as intended line". I am starting to lean towards some sort of cam- valve issue. If it was a harmonic resonance all 3.4's would have the vibration as its a design production issue.
Frank C.
Frank C.
If the problem doesn't happen in neutral it sounds like a car will need to be put on a dyno to identify the vibrating element.
That's very frustrating that you were able to show the dealer the noise and they said, yeah that's fine.
Good info thanks Frank, I'm going to try to confirm these today. I'm not sure if I would rule out exhaust, since the harmonic only happens during acceleration (in my case light acceleration). That would seem to rule out pure rotational harmonics, yes?
I wonder why the noise is unique to the 3.4 and not the 3.8.
I have been doing more research on the vibration issues discussed herein. Since we use the Boxter 3.4 engine I started reviewing threads from various boards. It appears that the problem is known to exist in the Boxster as well. While different solutions worked for different folks, the more common solution was replacing the dual mass flywheel. Now that I think about it, the noise vibration sounds a lot like the turning of the flywheel when it is not attached to the trans. I am not sure how our car is setup with the PDK, but I assume we have one flywheel.
