Fully turned steering wheel making weird noise with the tires
When the car is somewhat cold and I try to fully turn the wheels to either get out of the garage or maneuver the car it makes a weird noise (drivers side) which feels like I am driving on a ridged surface until I turn the wheel back to be straight ...its a strange feeling and quite frankly extremely annoying as nothing seems to be wrong with the tires....
thoughts or something I should look for?
Thanks in advance for any advice
Still wearing your summer tires? If so the issue is likely the cold, stiff warm-weather rubber compound making the noise as the tread blocks slip and skip rather than stretch and grip under the stress of the snow sharp turns. It's normal, but also an indicator that ambient temps are too cold for summer tires which lose their effectiveness starting around 40 degrees.
As BradB said, the issue is summer tires in the cold temperatures.
The factory tires are really only good down to about 45degF. Below that the compound is too hard. This is most noticeable, as you had described, at full lock, slow speeds, when first starting to drive after it has sat in the cold. The tire sort of grinds / skips along the road surface.
I switch to dedicated winter tires to prevent the problem.
It has nothing to do with temperature, it happens on a 90 degree day to me when I fully turn the wheel..
I don't notice it too much during warm days. Definitely temperature related and much worse on colder days.
ouch... turning the wheel while still.
Maybe we should have the MODS post a sticky Index or similar, with links to the most frequently posted topics? "Before you post start here" type of thing?
Oh, and let's BAN the relentless wheel posts from vendors and put them where they belong, in the classifieds! I get it, free market, democracy and all that, guerilla marketing, etc. But posting every two days "bump" to remind everyone that you can satisfy their every whim or need is so useless to those of us who come here to share experience, how-to's, ask questions, and generally share knowledge!
Ok, flame suit on, jumping down off my soap-box now!
