993Last generation normally aspirated aircooled Porsche 911. Community includes the C2, C2s, C4, Targa, C4s and cabriolet discussion.
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Does anyone have any pearls of wisdom to remove a stock 6-speed shift knob from a '98 993? I removed the center console to release the leather boot from under the console so that I could get to the knob on the metal shifter. There is no allen screw or fastening bolt securing the knob to the shift lever so I assume the knob is simply press fitted down onto the shifter. But try as I might I can't get the knob up and off. Any suggestions would be greatly appreciated. Thanks.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on 6SpeedOnline!
honestly, you may need to call your local dealer, if no one cant answer your question. do you have some pics? maybe that could help.
997 C4S Cab, with a K&N air intake, navi, bose, 6 speed, sport chrono,
i pod inter-grader, chrome tips, 3M bra, H.R.E C97's 19" 8.5F, 11.5R rear with michelin ps2. (P.C.A member)
Ducati 1098s with carbon fiber To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
996 Carrera Cab, Guards Red with H.R.E's 545R's 8.5F/10.5R. Sold
You don't have to remove the center console to get the boot out, all you have to do is just push down on the boot at the edges of it, and it will pop down and out of the clips. Once all sides are loose, then you can turn the base slightly and pull it out of the console. IIRC the 993 is just a press fit, so then you just pull up hard on the shift knob to remove it....sometimes is just takes a good long hard pull before it will let go and release. Shouldn't take more than a minute to remove start to finish.
I usually use a screw driver with a towel around the end and press down on the left inside part of the boot. It will release and you just pull up on the knob but make sure your head is not in the way.....ask me how I know.....
95 Carrera Guards Red/Black, PSS9/M030, 18" RUF's, Euro Turbo Bumper with Fogs and S Ducts, 1B Skirts, GT3 Steering Wheel and Shift Knob, HID's, Wide Ovals, LPMM by FisterD, Halotron, 36,916 miles and counting....
