996 Turbo / GT2Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2. Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
I wasnt complaining, I just couldnt find a place to buy one. Thankfully, RPM stepped up and sent one to me. Thanks again TIM!
__________________ 1996 993 C2 - Arena Red/Tan - PSS9, ROW Sways, TRG links, DACH X pipe, strut tower brace, Fikse Mach V's, Aero 1 splitters, Recaro PP, Fabspeed intake, 997 Shifter 2008 Lexus GS460 - Silver/Black - stock 1968 Cadillac Coupe DeVille - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
2001 996 TT Silver/Black - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
i dont think the stock wastegates come in two pieces. when i received my wastegate from EVOMS, it came unassembled and i had to fidget with it for a bit to get it right. once I got it all together, i had the dealer bolt them up but it had like a screw to put the two lines together? glad RPM took care of you guys.
Porsche 911 Turbo
With a few tweaks.
I got the same problem on my ponctuators, frst the left side broke, then 300 km later the right one...:-( Todd from proto knew about the rods failure from Evoms wastegate..welcome to the club...:-) Sorry for your troubles..
sweet cant wait until the other one breaks. So what did you do?
Same thing happened to me yesterday on the Passenger side EVOMS wastegate, the rod simply snapped in the middle. Did anyone find out any possible causes?
Quote:
Originally Posted by cohare
I noticed my car wasnt boosting properly the other day. I hadnt driven it in sometime so I wasnt sure if it was my head. I get under it today and I found that I have broken the passenger side rod that connects to the acuator on the turbo (as opposed to the one that connects to the evo supplied diaphram)
Does anyone know where I can find a bent rod like that. I have emailed mike at evo but if you are on please help!!!! Also, it says he is not allowing PM's, are they still a sponsor??
Anyone else ever had this problem? Any ideas on causes?
UMW 2C & LWFW - X73/light suspension work - EP2Loud - GT2 brakes and body work -
Custom 996turbo/997GT2/997GT3RSR tranny - and probably some other **** I forgot.
You guys needto contact EVMOS and havethem provide a replacement. Sees to me that the parts are flawed. I also was thinking of getting a pair but not until they fix this issue........
Founder and National Advocate
Porsche Club Of America 911 Turbo Registry To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
None of the actuator rod pieces will work with your after-market turbo. The compressor housing is larger, hence all the bends in the assembly. I have broken several. Tial sent me some made of stainless steel that I ran for awhile with no breakage.
Roadster Doc is exactly right about the threaded rod. The stress risers created by the bends on a rod that has cut threads will ultimately lead to failure with any of them, in my opinion.
The ultimate solution, albeit expensive once all plumbing is done, is to go to Tial 44mm external waste gates. You can control your boost with the spring or spring package in the WG and can make an even better setup if you add an electronic boost controller.
If you are looking for just an increase to 1.1-1.2 why don't most programs just have this threshold of 1.1-1.2 written in the ecu code like fvd does? with the fvd program there is no need for these spring upgrade. the stock version works fine with the fvd turbos and set up.
oak
Don't get exactly what you mean. As I understand it the code is what is responsible for sending the message via rubber hose to the wastegate actuator which in turn opens the wastegate. Otherwise it would be entirely spring-dependent and not a function of commands from the ECU. How would the wastegate hold boost until the proper time without the ECU telling it to do so and having the actuator rod iinvolved to control the gate?
Surely the FVD setup involves a wastegate actuator rod? this guy just wants to stop breakage and probably without swapping out his turbos.
sorry for the misinformation al, the fvd uses an electronic boost control and uses the stock wg's.
yes the fvd turbos have an actuator rod and appears to be stock these don't appear the ones to have problems with breakage. It's the EvO units that have a track record of breakage as the Evo units are different than the stock version. Are the rods of a diff design?
oak
