996 Turbo / GT2Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2. Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
i think we can all agree that the k24/18g , with a 5bar, on 93 pump , on 1.1 bar is good for about 520rwhp....
being that the OEM injectors are 40lbs, we're increasing the flow rate of the injectors by 50%
would the STOCK fuel pump/fuel rails be able to run efficiently ?
also... would i be able to run 1.3 bar on 93 ?
my goal is 570-580rwhp on a mustang dyno , SAE uncorrected
btw, i will NOT be running an EBC, as the car will never see race gas
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on 6SpeedOnline!
"It's a funny thing about a porsche... There's the moment you know you want one...
There's the moment you first own one... And for the truly afflicted there's a decade or two that passes in between." 02 911 Turbo Stage 4
theoretically speaking, on a 0 shift, with a brake boost file on the car... how possible is a 5.9 60-130 ?
You need the Vivid kit or a top local mechanic who can fabricate (or ship your car to Protomotive) and a set up with GT3076's and race gas and excellent driving skills and excellent conditions to run a 5.9.
Why in Gods name would you not want to run quality gas in your car?
2002 Porsche GT2 with GT 30's Tuned by Protomotive. 60-130 Street Tire Champion Tx2K8 and Tx2K9.
2004 BMW Individual M3: BHS Supercharged Stage 2. 8.59 60-130
2009 Mercedes E350
2004 Porsche Cayenne TT.
Jamie carters car had all that (well maybe not the excellent driving skills..he had C16 though) PLUS Gt3076A/R 82's and ran a 5.93.
24/18's should easily beat a Ruf 590 (we had an RT 12 here....my car crushed it's 60-130 times) but to beat that Corvette (it is a new Z06 w/ intake, ehuast, cam and tune, yes?) properly you need GT 30's.
24/18's and a fuel system should have you edging the Corvette by maybe a length but for a proper as$whooping, go 30's.
2009 Mercedes E350
i think we can all agree that the k24/18g , with a 5bar, on 93 pump , on 1.1 bar is good for about 520rwhp.... With this same setup I made 483-ish WHP at epl, 1 bar...
being that the OEM injectors are 40lbs, we're increasing the flow rate of the injectors by 50% You won't need 60# injectors with this setup... stock will work fine. Ask Todd K, Paul or John from Proto. The've built many cars with this setup. Take the money you were gong to spend on the injectors and install and put it towards a EBC.
also... would i be able to run 1.3 bar on 93 ? Stock fuel pump, rails will be fine. 1.3 bar....I don't think so I believe 1.3 you "should" run at least 104... 1.2 is max (safely) on 93.... but then again I am a bit conservative and if I run higher boost will most definetely run better fuel. 1.2 is max I would run on 93..... you should consider the mileage you have on your engine and do leak down/compression test before running boost above 1.3....
my goal is 570-580rwhp on a mustang dyno , SAE uncorrected I think to get to this level you will need 104 and EBC...
btw, i will NOT be running an EBC, as the car will never see race gas add the ebc especially if you like to drive the way you do (mexico runs). Find a good source for fuel (a few places in NJ carries it). EBC makes a HUGE difference, at least it did in my car.
Last but not least have you also considered a new clutch? with this power level the stock one will need to be replaced sooner than later.
__________________ Alan 01 996TT Proto 650 04 Cayenne Turbo Proto Stg2 01.5 WB S4 Avant KMD Tuned Gt28RS 635hp (low boost @22PSI)
Add the injectors and EBC. The EBC will make a big difference, and the injectors are great for safety, especially at higher boost levels with the EBC.
__________________ SWITZER Exhaust Specials : PM for more info
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Wes Bourne
phone: 407-277-8423 x226
aim : onelovewcb
email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
2003 996TT K24-18G / 2007 BMW X5 4.8i / 2003 BMW M3 SMG
i have a clutch that can handle 700rwhp.. ... ceramic
I agree with Wes. Do the injectors. 400 bucks worth of injectors now can save you alot later.
At the power level your going to be at, with out injectors you will be at 100% of the stock injectors capacity.
Tony, are you getting emails? I've emailed you twice with no reply...not like you...
Steve Kojasevic..
I am getting ready to do the exact same thing you are. As a matter of fact, I just blew my stock clutch at only 425whp. I am going to do 24/18g's, injectors and maybe 5bar..oh yeah and a new clutch. Keeping stock intercoolers and fuel pump for now. Hoping for 500-525whp with this combo.
__________________ 03 996TT, 24/18G's, 58lb Injectors, FVD Sport Mufflers, Custom EPL Tune w/Meth Inj. 5.99 (60-130), Best ET-11.14, Best trap-133 Texas Mile 09: 195.024 in 27.4 sec (0-186 - 23.8 sec)
Usually you do not change the FPR, if you install larger injectors.
John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. (1.24 bar - 104 octane) 2002 996TT/EPL Tuned - K24/18G turbos, SpeedTech 70mm intake w/75mm Y-Pipe, 75mm TB, 60lb. injectors, SpeedTech exhaust, non-assist clutch, Greddy, PSS-9, GT3 seats
Steve Kojasevic..
resend mike and cc sales@eplabs.net... I am having email issues. =/
Hey Tony,
Which injectors are you using? Looks like I should be considering them as well... Will I see any power gains from going to larger injectors without the fueling/intake kit?
just a little confused here
why couldnt i run higher boost if im getting bigger injectors ?
wouldnt i be able to put more air in ?
By putting more "air" in the motor, you are also increasing cylinder pressure, and you need the extra octane along with extra fuel. Take everyones advice, and plan to run GOOD gas with boost levels above 1.1-1.2 bar.
Tim
'02 Silver TT Techart front and sides, 19" DPE wheels, GT2 wing, EPL tuned. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 1.1 bar (Sold)
'98 Supra TT White/Blk 6spd (Sold)
'01 IS300T 703whp To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. (mid boost) Rear decklid/wing for sale arctic silver
