996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2.
Sponsored By Vivid Racing |
Welcome to 6SpeedOnline.com! |
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
09-04-2008, 02:06 PM
DIY- PS Pump and Reservoir change
10-17-2008, 04:09 PM
any tips on how to remove this bolt??
2002 911 Turbo
1994 Supra Turbo
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
10-18-2008, 09:42 AM
excellent write up- thanks for posting!
2001 Porsche 911/996 Twin Turbo,
Upsolute ECU Flash, K24's, Remus Exhaust, Evo DV's, SSK, Triple Black with Arctic Silver Trim, CF Wing
2001 Acura MDX- Family Mobile
1984 Chevy El Camino- Daily Driver
12-28-2008, 09:28 PM
Thanks for the post and pics
Lowered the engine and replaced my secondary air pump, change over valve and 3 check valves-and I forgot to take pictures. You saved my life!
2002 996TT Triple Black-UMW
2006 M3 Comp
12-29-2008, 12:40 AM
Quote:
Looks like I missed this post a few months back. Looks like your car is a manual. Mine was a tip and didn't have these lines. They do look like "brake line" type fittings. I'd either use a flat wrench or if it is really stuck, vise grips usually work best for me.
04-02-2009, 09:45 PM
Hey guys, I still can't get that one bolt off that I circled in the picture.
I've even tried a brake line wrench.. any other tools I can use???
if i turn it anymore then it'll just strip.
2002 911 Turbo
1994 Supra Turbo
04-02-2009, 11:36 PM
Brake line wrenches suck as althou they are HEX they still flex because of the slit and will round these out. Vise grips set up right will grip it strongly enough not to strip it. Also, since the fitting is steel and the reservoir is aluminum, soak it with a penetrator first. Worst case scenario, you'll learn how to use a double flaring tool
2002 911tt -Current DD and WW CF Mirrors, CF Ruf Spoiler, GT2 Bumper
1989 Ford Mustang 5.8- Far from Stock, never finished or running
2005 Triumph Sprint ST
2004 BMW R1200C Montauk
2003 S500 4-matic RIP
2003 BMW Z4 3.0 -Sold
04-14-2009, 03:18 AM
Quote:
Thanks for the tips.
I finally did it. I officially hate Porsches.. so far I've replaced spark plugs, intercoolers, clutch accumulator and the power steering reservoir.
ALL of those are harder than any car I've ever worked on.
Also, when I took the drive belt off.. I didn't line the pulleys in the same spot as they were before.. now they're all outta whack.. is that ok???
2002 911 Turbo
1994 Supra Turbo
04-20-2009, 08:05 PM
SXN,
How did you finally manage to get the lines off? I just started hearing this noise today and I think I may try to tackle this job in the near future. When I changed the alternator I didnt line the pulleys up and have not noticed any ill effect. Did you change both the pump and reservoir or just the reservoir? Has the noise gone away with the change?
02 996TT FVD flash and exhaust
04-21-2009, 12:30 AM
Quote:
Originally Posted by blackonblacktt
SXN,
I took adams advice and used vise grips. Worked like a charm.
I replaced the reservoir, there's no need to change the pump.
It's a 997 reservoir that you replace it.
put aside a lot of time for when you do this. There's some tricky bolts man.
2002 911 Turbo
1994 Supra Turbo
04-21-2009, 01:15 AM
Glad it worked
Make sure you guys tighten them up pretty good, but not too much. Also you have to be very careful not to cross thread them. It's best to just clean'em up real good and use your fingers for the first few turns. Also, triple check for leaks after you run it and use the clutch/PS.
04-21-2009, 05:49 PM
adam, thanks for posting this, I need to change mine out. it's been making the noise for awhile.
anyone have the actual 997 part number?
TIA
oak
04-21-2009, 05:57 PM
99731492031
I got mine last week from Jeff Clark at Sunset Porsche phone 1-800-346-0182
Ed
04-21-2009, 06:01 PM
thanks ed!
oak
11-04-2009, 05:12 PM
subscribed
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
User CP
Visit our Sponsors
6SpeedOnline.com
Threads:
Members:
