Go Back   6speedonline.com Forums > Porsche (Present) > 996 Turbo / GT2
New! Use your Facebook to securely log into this site, click logo to login
996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2.
Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 10-15-2008, 04:34 PM #1
Tony@epl's Avatar
Tony@epl has a reputation beyond reputeTony@epl has a reputation beyond reputeTony@epl has a reputation beyond reputeTony@epl has a reputation beyond reputeTony@epl has a reputation beyond reputeTony@epl has a reputation beyond reputeTony@epl has a reputation beyond reputeTony@epl has a reputation beyond reputeTony@epl has a reputation beyond reputeTony@epl has a reputation beyond reputeTony@epl has a reputation beyond repute
Water injection testing on the 996tt : Complete.
What is water injection?
Water injection is the process of spraying a fine mist of water and possibly a mix of other mediums directly into the combustion process. This can take place directly in to an intercooler pipe or directly into the intake manifold. This mist absorbs and displaces heat caused by the compression of air through a turbo system.
Please do not confuse this process with spraying water on the external surface of intercoolers. Fine mist of water is actually entering your combustion chamber.
Advantages of water injection:
-Significantly lower intake air temperatures
-Lower egt’s
-Reduced risk of detonation
-Reduction in ecu timing retard
-Increased octane (when used with methanol)
-Reduced carbon build up in cylinder
-Ability to safely run more boost on pump gas
-Ability to advance timing further then pump gas alone
The Test Car:
2001 996tt
Cargraphics Exhaust
Forge Diverter Valves
EPL Flash
The Install:
The install of each system can be tailored specifically to customer specification and needs. In the case of this car, we used a 6 quart tank mounted in the front of the car, the pump was mounted in the spare tire well and lines were run through factory grommets to the engine compartment. This install caused the owner to loose less then 1 cubic feet of storage space and will not effect the day to day use of his storage compartment.
Jet Placement
Tank Location (this pic taken before wiring was neatly tucked away)
Test Data:
Intake air temperature:
Notes : This graph displays data from a back to back 3rd gear pull. Notice the reduction of temperature during the 2nd dyno pull with the water injection switched on.
Water Injection on – Delta Change of temperature -3.7c
Water Injection off – Delta Change of temperature +13.5c
Ignition timing:
Water Injection off
– Notice the different in timing advance at 3000-3300, 5000-6800. This is due to the ecu pulling timing based on knock sensor activity. This happens on most if not all tuned 996’s.
Water Injection on – Notice smoothness of the timing curve with the water injection system active. The ecu did not retard timing nearly as much as with the system deactivated. This is VERY similar to what you would expect to see if the car was running race gas. This additional ignition advance will greatly increase horsepower and smooth power delivery.
Dyno:
Green Graph – Basic off the shelf EPL k16 flash optimized for 93 octane.
Red Graph – Newly released off the shelf EPL k16 water injection file optimized for use with 93/92 octane and water injection.
Gains :
-25+ horse power and 30+ foot pounds of torque through much of the power band.
-As much as 40+ horsepower gains in some areas.
-Much broader power delivery.
-Better throttle response.
Conclusion:
When a high quality water injection system is installed and tuned correctly, it will increases both power and safety in the 996tt application. The benefits of lowering intake air temps even beyond what upgraded intercoolers can do and increasing octane to your a/f mixture are just 2 of many advantages of installing a system like this.
EPL recommends the Aquamist HSF-1 or HSF-5 kit. Specific 996tt kits are available from EPL. Please email or PM for more information.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
Tony Chick
European Performance Labs
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
203.345.6499
2008 Cayman S : 2002 996tt : 1985 Audi URQ : 09 Mini Cooper
Old 10-15-2008, 04:42 PM #2
wagongotya is on a distinguished road
Wow, great post and great results! Nice work Tony.
Old 10-15-2008, 05:30 PM #3
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
Wow. Great work guys! Save one for me.
2002 Slate Grey 996TT - K16/16G Hybrids; DGI/Speedtech 60mm exhaust; Clutchmasters custom stage 3 (kevlar/organic hybrid disc); EPL Custom Dyno Tune; Bosch 710N DVs, 997 Shifter; 18" Champion RG5 Monolites - A$$ Hauler
2007 Q7 - Family Hauler
Fond Memories:2001 Audi S4; 1990 BMW 525i
Old 10-15-2008, 06:03 PM #4
pumalex's Avatar
pumalex has much to be proud ofpumalex has much to be proud ofpumalex has much to be proud ofpumalex has much to be proud ofpumalex has much to be proud ofpumalex has much to be proud ofpumalex has much to be proud ofpumalex has much to be proud ofpumalex has much to be proud ofpumalex has much to be proud of
have you guys used only water or did you add some methanol?
Old 10-15-2008, 06:13 PM #5
Tony@epl's Avatar
Quote:
Good question. I should have specified. This was 50% water 50% VP m1 methanol.
We would have seen nearly the same results with windshield wiper fluid. Most windshield wiper fluid is 30% meth or more.
Tony Chick
203.345.6499
Old 10-15-2008, 07:03 PM #6
TXGold's Avatar
TXGold has a reputation beyond reputeTXGold has a reputation beyond reputeTXGold has a reputation beyond reputeTXGold has a reputation beyond reputeTXGold has a reputation beyond reputeTXGold has a reputation beyond reputeTXGold has a reputation beyond reputeTXGold has a reputation beyond reputeTXGold has a reputation beyond reputeTXGold has a reputation beyond reputeTXGold has a reputation beyond repute
Will this solve the heat issue you find inherent with the 20G wheels being used?
2002 996TT SOLD -
Old 10-15-2008, 07:07 PM #7
Tony@epl's Avatar
Quote:
It would be a band-aid fix....but yes it absolutely would.
Tony Chick
203.345.6499
Old 10-15-2008, 07:17 PM #8
TXGold's Avatar
Would the gains be additional if race gas is used?
2002 996TT SOLD -
Old 10-15-2008, 07:20 PM #9
flash68's Avatar
flash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond repute
Great write-up Tony. Very cool.
I have a water-injection kit that came with my procharged small block Chevy and cannot wait to get that running!
Alpha 28rs, Aquamist HFS-1, 72# injectors, EPL tuning, Protomotive ICs, Fabspeed Maxflo, RWD, modded by Sharkwerks, S-Car-Go, and Elite Motor Cars.
For Sale:
Old 10-15-2008, 07:23 PM #10
Tony@epl's Avatar
Water injection is perfect for 91 octane applications! You car is going to love it.
Tony Chick
203.345.6499
Old 10-15-2008, 07:25 PM #11
BlackBear's Avatar
BlackBear has a spectacular aura aboutBlackBear has a spectacular aura about
Great data and documentation.
I'd like to see this on a 700 HP car.
A car with just a chip might not mean much. How much of a delta will you get on a high HP application.
I know that PorschePHD, ImagineAuto, built a very nice Aquamist system about three or four years back and then we never heard about it and nobody ever used it again. I'm not sure what the reasons were. I was ready to do this then.
Old 10-15-2008, 07:35 PM #12
Tony@epl's Avatar
The Aquamist pumps that were available a few years back weren't adequate for high horse power applications. This system set up and tuned properly on a high horsepower 996 would be fantastic!
For what its worth, in most cases a k16 at 1 bar will produce more heat then a k24/18g at 1 bar.....delta change would most likely be nearly the same or even more idel!
Tony Chick
203.345.6499
Old 10-15-2008, 07:43 PM #13
Divexxtreme's Avatar
Moderator
Divexxtreme has a reputation beyond reputeDivexxtreme has a reputation beyond reputeDivexxtreme has a reputation beyond reputeDivexxtreme has a reputation beyond reputeDivexxtreme has a reputation beyond reputeDivexxtreme has a reputation beyond reputeDivexxtreme has a reputation beyond reputeDivexxtreme has a reputation beyond reputeDivexxtreme has a reputation beyond reputeDivexxtreme has a reputation beyond reputeDivexxtreme has a reputation beyond repute
Nice job, Tony. I'm very glad to see someone finally apply this to P-cars.
Scott
TPC Racing/Protomotive PE900 '03 GT2: 60-130: 5.49
Protomotive PE1000 '01 TT: 889 rwhp (SOLD)
1/4 mile: 10.45/148 - 60-130: 4.67
'06 Black C6 Z06: 722 rwhp (SOLD)
60-130: 5.74 modded, 7.86 stock
'98 Quicksilver Supra: 711 rwhp w/bolt-ons (SOLD)
'05 & '03 E46 M3 (SOLD)
'03 Cayenne S (SOLD)
Old 10-15-2008, 07:50 PM #14
Tony@epl's Avatar
Quote:
We've had a couple 996's running for a while, but no one has been able to leave their cars with us long enough for proper testing.
I personally will never own another force induction car without water injection. I actually have a kit on the way for my cayman.... Lets see what we can do on an NA car!
Tony Chick
203.345.6499
Old 10-15-2008, 08:07 PM #15
TXGold's Avatar
2002 996TT SOLD -
Reply
Tags
600, 930, 996tt, advance, h20, hsf1, hsf5, injection, jaguar, meth, nicklesil, porsche, s4, timing, turbo, water, whp
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Contact Us - 6speedonline.com - Archive -
Top
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
