Go Back   6speedonline.com Forums > Porsche (Present) > 996 Turbo / GT2
996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2.
Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 11-29-2008, 05:02 PM #1
N1_kT is on a distinguished road
Send a message via AIM to N1_kT
HELP....Radiator hose keeps popping off
i keep having my radiator hose pop off. its the one on the right side connected to the engine. What could cause this? Any help would be great. thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
Old 11-29-2008, 11:18 PM #2
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
What a nasty (and expensive) recurring mess to deal with! I had that hose burst once and the coolant was sticky and expensive. I recommend that you replace the hose. The fittings are similar to the boost hoses with stamped aluminum tabs that are held in by C-clips on the cast aluminum housings. Those tabs may be worn on your hose. It is also possible that the hose was not pushed in far enough to clip securely in place. Good luck.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Old 11-30-2008, 01:02 PM #3
al@cpt's Avatar
al@cpt is on a distinguished road
Provided the car is not overheating, I would inspect the radiator hoses and replace the clips and o-rings. If the hoses are old replace them as well. New hoses come with o-rings but you will need to get clips. An air pocket might be causing this to occur, so make sure you properly bleed the system. Also, the bleed valve and cap must work properly.
Old 11-30-2008, 02:38 PM #4
what is the proper way to bleed the coolant system and to eliminate all the air pockets.
Old 12-01-2008, 07:46 AM #5
al@cpt's Avatar
I use a tool that creates vacuum in the cooling system. Here is what I have: http://www.brightsol.com/pdf/radiatormiser.pdf . This will do most of the work and eliminate most of the air pockets. Then you need to use the Porsche system tester to finish bleeding the system. I hope this helps.
Old 12-01-2008, 03:15 PM #6
i found the problem, it was a bad clip. thanks for all your help
Old 12-01-2008, 07:31 PM #7
Member
To bleed the system yourself without any special equipment, place the rear of the car on jackstands as high as possible. Chock both front wheels. Fill the coolant tank, start the car and let it warm up. Top up as needed. Rev it a few times, let it idle, top off if needed and and shut it off. Once fully cooled, check and top up again as needed. Take it off the stands, drive around a bit and keep your eye on the T-stat. Let it cool off, check coolant level and top off as needed. Keep checking T-stat and coolant level (when cool) for the next few drives.
Old 12-02-2008, 08:30 AM #8
onelove's Avatar
Premium Sponsor
onelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond repute
Send a message via AIM to onelove
Turn the heater on as well when you're doing so doc. Also check the lower back hose for wear from time to time. I've seen in both our cars where this piece can hit the engine mount, and had one rupture as a result.
SWITZER Exhaust Specials : PM for more info
Wes Bourne
phone: 407-277-8423 x226
aim : onelovewcb
email:
2003 996TT K24-18G /
2007 BMW X5 4.8i / 2003 BMW M3 SMG
Old 12-02-2008, 12:06 PM #9
Member
Yep. I had one split (driver's side) at only 21k miles!
Reply
Tags
hose, hoses, pop, popped, popping, pops, radiator, top
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
