996 Turbo / GT2Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2. Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
it feels like everything kicks is at 4000 rpm, but it takes like an hour to get there.
what can i do to the car thats not too crazy, and is still pretty much stock
will ecu programming give me the low end bump im looking for?
i dont have the x50 package, and i dont plan on changing the turbos ... so i dont want to do something that will mess up the car.
thanks in advance
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on 6SpeedOnline!
2 SL55'S WITH BLOWN ENGINES...SO I NOW HAVE A 996TT CAB
2004 cobalt blue 996 tt cab, 6 speed, black interior, black mats, cd changer, no hard top, heated seats, sport seats, Porsche crest in head rest, large aluminum package, aluminum steering wheel, aluminum shifter/brake handle, aluminum door handles, center console in cobalt blue, back of sport seats in cobalt blue, aluminum pedals, techart side skirts, gt2 front bumper, gt2 wing, techart rear bumper, 993 style hood, oem ssk, kreis-seig exhaust with switch, GIAC flash, painted bumperettes and keyhole plugs, 2 10" jl audio w10 woofers, a 12 pack of oil
You have the first symptoms of modaholism. That's how it
starts...
Seriously though, check your boost. Get someone to look
at what your boost meter says, while you floor it from
2000rpm to 4000rpm. If it doesn't get to .8 bar, maybe you
have a boost leak. If you haven't replaced your diverter valves,
do that.
Joe
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
perhaps its that new exhaust you put on. I am sure you know that an exhaust is the most important thing on a turbocharged car.
__________________ 2007 Shelby GT 500 White w/ Blue Stripes Coupe - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
571rwhp 543rwtq SAE 1.62 60' 11.41 @ 125.71 - ET Streets 1.91 60' 11.86 @ 125.26 - Street Tires 1.64 60' 11.59 @ 118.22 - ET Streets (Stock Pulley)
2004 Black Cobra Convertible (gone To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ) 616rwhp /570rwtq SAE KB 2.2 at 19psi 7.24 @ 93 11.3 @ 123 missing 3rd (2500' DA on 17" DR's)
RIP Ben. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
I have exactly the same problem with my car (stock '03 996TT)and it happened right after I installed an aftermarket exhaust.
The boost does not kick in until 4K rpms, then from 4K on up it goes like crazy and I am gettin .8 bar peaks. Also the boost on the gauge is not increasing linearly sometimes going from 0-.4-.8, other times from 0-.8. I am not seeing the .8 bar peaks unless I am over 4K rpms. I have a vacuum test scheduled for Friday to see if the DV's are leaking. At this point I don't know if this is a common occurence with aftermarket exhausts that are not chipped or something else.
do u have any vacuum leaks, ? coz a simple thing like a vacuum leak can cause havoc to a turbocharged car...
also learning how to launch your "coche" will greatly improve the accelaration of your car.. one thing to remember try to keep the rpms, in the sweet spot of the rpms... and to get the max hp and speed of the car shift at the tip of the car's "bell curve" ...
i hoep this helps and yes we need better pics of your car:
Launching fast and smooth with the TT's zero-feedback-clutch and short-legged 1st is a miserable exercise. Better to just roll it out of the gate and then go, imo.
Should've gotten the Tip. You can floor it next to the M3's without worrying about stalling.
no fun ... my sl was a beast off the line .. i miss the feeling of head snapping back ... its not for racing
Originally posted by AdamT Rev the car to 5krpm and bring the clutch up till it starts to bite.
Dump the clutch, release the handbrake and give max throttle a
I find it's the "starts to bite" part that's hard to feel. Too much bite too soon and well...
Reving to 5k rpm at a stop light also gives too much warning to other party and gets too much unwanted attention.
Besides, you don't want to do that every light.
I prefer to try and get a perfect timing on clutch engagement with a bit of slippage, and proportionate throttle together to get a smooth and swift launch.
