996 Turbo / GT2Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2. Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Hey guys, I am doing a spark plug change out and while I am in there would like to check the compression. Does anyone know how to do a test? I would like to disable the injectors but dont know which fuse to pull? Any help would be appreciated.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on 6SpeedOnline!
You need a professional type dual unit (2 guages) that goes up to 100psi. The other gauge has the % meter.
you pressure each sparkplug hole one at a time up to 100 psi then stop and wait to see where the loss in % stops...
write it down and move on to the next one...
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
powered by Protomotive 773-552-0653 direct line- we specialize in custom made parts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
01 996TT - 9.91 sec.145.64 mph 1/4 mile (4.62 sec. 60 to 130mph) 06 CLS AMG
Hey Mark, I think your referring to a leak down rather than a compression test. I would like to do a compression first and if there is any low #s then I will do a leak down. I just need to know how to disable the injectors really. Im just going to leave the coilpacks unplugged. I figured it would just be a fuse I could pull to disable them?
I just have a single gauge leakdown tester.... what is the difference between the single and dual?
unplug all your coils and make sure ALL your spark plugs are out. turn engine over until the needle stops increasing. shouldn't see more than 15%-20% delta between cylinders, hopefully WAY less.
__________________ 03 996TT, 24/18G's, 58lb Injectors, FVD Sport Mufflers, Custom EPL Tune w/Meth Inj. 5.99 (60-130), Best ET-11.14, Best trap-133 Texas Mile 09: 195.024 in 27.4 sec (0-186 - 23.8 sec)
when i do this i always do it the same way.
1. remove all the spark plugs so the engine will turn easy.
2. block open the trottle (stick a screwdriver handle into the thottlebody)this will prevent airflow resistance.
3. disable the ignition system to prevent sparks(remove the feed wire to the coil).
4. disable the fuel injection.
5. screw the gauge on with the right adapter in the sparkplug holes.
6. crank the engine and listen for about 5 compression strokes(the needle will move as this happans).
7. Write down the numbers and repeat these steps in all cylinders. if the test fails try adding a little oil to the cylinder and see if the rings are fried if not check head gaskets and valve seats and seals.
re: Fuse
Look for a DIY oil change post on here ?? I remember seeing it there as to crank the engine to prime the oil pump vs firing it straight up after an oil change.
Let me add 2 things...
0. Make sure the car is up to running temp before starting. This may make it tough to work on because its hot, but results wont be accurate if its cold.
6.5. After you are dont cranking a set number of times, crank a second time until the needle stops moving.
