Go Back   6speedonline.com Forums > Porsche (Present) > 996 Turbo / GT2
996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2.
Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 02-05-2009, 07:55 PM #1
audikp's Avatar
audikp is a glorious beacon of lightaudikp is a glorious beacon of lightaudikp is a glorious beacon of lightaudikp is a glorious beacon of lightaudikp is a glorious beacon of lightaudikp is a glorious beacon of light
Send a message via AIM to audikp
DIY: Removing Steering Wheel and/or Airbag
Figured I'd post this up for the archives.....
1) Disconnect the battery
2) Behind the steering wheel on each side there are screws which old the airbag in place. Start by popping out the covers over the screws. Then use a T30 to remove both screws. Note: I found it helpful to turn the wheel so the screw was at the bottom...this gave me more room to get the tool to fit.
3) Once both airbag screws are lose the airbag will come out....it is held in by a wire with a yellow plug. Use a flat head to pop the plug out of the airbag.
4) Next make sure your wheel is straight....and if you want to be precise you can mark the nut and center bolt with white out or a sharpie so you can put the steering wheel back on straight.
5) Remove the nut on the center bolt with a 24mm socket
6) The wheel should pull right off....gently rock it side to side if it doesn't come right off.
It goes back on in reverse
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
2001 996 TT EPL / TiAL 3071 + Water/Meth (724awhp /776ft.lbs)
2001 EPL RS6 Stg3 S4 (440awhp / 479ft.lbs)
Old 02-06-2009, 12:26 AM #2
Slow4s has a spectacular aura aboutSlow4s has a spectacular aura about
Cool! Thanks for the post, will come in handy one day.. Someone please give this guy some rep points!
Thanks,
Alex
Old 02-06-2009, 08:09 AM #3
M32's Avatar
M32 M32 is offline
M32 has a brilliant futureM32 has a brilliant futureM32 has a brilliant futureM32 has a brilliant futureM32 has a brilliant futureM32 has a brilliant futureM32 has a brilliant futureM32 has a brilliant futureM32 has a brilliant futureM32 has a brilliant futureM32 has a brilliant future
Send a message via AIM to M32
Thanks KP
Quote:
Thanks,
Alex
Alex, I'll do it
Edwin
K16 Hybrids, DV, FPR, CG Exhaust, AP CF intake, EPL Tune - 464hp, 506 tq
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Old 02-08-2009, 05:05 PM #4
Alpha is on a distinguished road
auidikp -- Thanks for the DIY!
Old 04-25-2009, 09:12 PM #5
DHI's Avatar
DHI DHI is offline
DHI is on a distinguished road
Good DIY.
It is as easy as it sounds.
DI
Reply
Tags
2000, 944, 964, air, airbag, bag, chevy, cooper, diy, malibu, mini, porsche, remove, removing, replacement, steering, tools, turbo, wheel
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
