02-22-2009, 09:24 PM
996tt KW v3 Suspension " too bouncy on street " setup thoughts plz ?
Okay, I have a nicely corner balanced setup with KW V3 suspension. While watching my friend drive my car i could see the rear end bounce around a bit too much on a regular main road. I have tried a few different settings but would like the forum's input plz. I opened up the rebound on all four almost all the way and i feel it helped greatly. the compression is set 5 clicks from close on all four, i enjoy a stiffer ride ( even though the progressive springs are not all that stiff )
Thx
DW
KW SUSP - SACHS L.W. FLY --GT3 SEATS - DAS ROLL BAR - RUF 550 EXHAUST
02-23-2009, 03:55 AM
KW V3s are a great product and I haven't tuned them at all, but what I did notice is that if I leave the front settings on my PSS9s set to 2 clicks from full hard and the rear set at full hard, I have a very compliant ride and well balanced (As low as the lowest GT2 stock ride height setting). If I soften the rear up even ONE CLICK I get a LOT of rear bounce.
I know that doesnt' help with your specific setup, but it does give you an idea of how much finding the right balance is just "fiddling" until you get there!
Mike
Daily Driving a GT3 and Developing a 35 year old Datsun Track car... Yea I'm Nuts.
02-23-2009, 04:17 AM
Pss9 and gt2 height is a big no no
2007 Turbo RSR
02-23-2009, 04:50 AM
02-27-2009, 10:24 PM
Nice videos and great runs. What's the best setting with PSS9 on the track? Thanks.
02-27-2009, 11:01 PM
great video what class you driving with ? what level ?
02-28-2009, 04:57 AM
Thanks for the compliments... I'm in the advanced solo groups in most of the clubs I run with.
I set my "poor" and "limiting" PSS9s at 2 or 3 on the front (depending on how bouncy the track is) and full stiff on the rear. I set the H/Rsway bars to full soft on the front (helps much with understeer) and medium on the rear. HRs only have three adjustment holes, unlike the GT3s.
The key to great times *(other than lots of track time) is the ability to dial in as much camber as possible and to dial out the added caster that the negative camber creates. I would run at 2.9-3.0 negative front on camber with caster set at stock values.
Here's the downer there... Front OEM camber adjustment maxes at 1.5 negative and there is NO adjustment for caster. NONE. You must buy adjustable thrust bushings to dial out the added caster.
On the rear, I ran 2.5 negative. This worked very well for tire wear on my MPSCs both front and rear. The toe was set to Zero front and 5mm toe IN at the rear.
When I was starting out with this car two years ago, I didn't have the "need" for more negative camber, and I wasn't killing the outter edges of my MPSCs. However, by beginning of the second season I started cording tires. The outter edges would start wearing faster. This was directly linked to my lap times. The faster I was going into and thru the corners, the quicker a set of tires would start to show severe wear on the outter edges. I used a pyrometer with a probe to find that the outside 1/3rd of the tire would be as much as 50 degrees higher than the rest... The inner edge was the coolest. What I did to help with this was to get some GT3 front control arms, and Dan at Vivid hooked me up with some of his rear dogbones. I had Lufteknic do a full track alignment for me and instantly I was quicker. Timing was good because I bought a Traqmate just 2 events before doing the suspension upgrades and I could compare all of the data from those events to the events where I was running more negative camber with a more aggressive overall alignment. The results were very eye opening...
Mike
03-01-2009, 05:37 AM
Quote:
Originally Posted by Mikelly
No not a myth at all, do the searching then you may understand
And wy are you say reduse caster that are the wrong way to go, aroung 9 degrees are right and up tp 11 are used on cup and rsr car..
2007 Turbo RSR
03-01-2009, 06:35 AM
SMR, I'm not going to argue with you. My proof is in the setup that is working for me.
And there is no appreciable adjustment in caster from the factory. So when you cram a whole lot of negative camber into the setup the front wheels get pushed into the front fenderliners. THAT is a problem. Maybe not for you, but for the rest of us, it is a big deal. The geometry of the TT won't allow you to follow the "cup car" standard. But hey, whatever floats your boat.
Mike
03-01-2009, 06:40 AM
Mike
I do not have a TT i have a better ground to work on, a gt2
Yes the front feders will get rubb but that life when racing, the car will behave alot better with more caster, or if the fenderliners are your bigg problem go with mantley yoppmonts then you can adjust caster up there without moving the wheel forward, i have worked on this suspetion for years now and a friend of mine worked with setting up RSr at le mans before so he know his game
2007 Turbo RSR
03-06-2009, 12:26 AM
What's wrong with pss9 w/ gt2 ride height?
03-06-2009, 04:24 AM
The earth will stop rotating and the polar ice cap will melt.
Apparently everything I'm not experiencing.
Mike
03-06-2009, 12:33 PM
I assumed you do not have any personal experiences with such setup... I know you love your GT2, but please don't bash on TT.
Quote:
03-06-2009, 04:12 PM
you guys, this was my thread on tips for setting up kw v3 's !!! : >
03-06-2009, 04:54 PM
Sorry bro for stealing your thread. My brother just got his set of KW V3 for this Supra TT. They are not installed yet, but the build quality is superb. Hear great things about them. Good luck on the tuning.
Tags
996tt, balance, bmw, bouncy, car, corner, kw, kwv3, m3, pss9, s2000, suspension, v3, vw, wheels  |
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
