996 Turbo / GT2Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2. Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Stock wheels are easy, it gets complicated when you start changing wheel widths, which most of us do. If you go by tirerack, there is a chance that what starts off as equal or near equal overall diameters can be skewed by the tire's fit on the wheel. Meaning if you are on the narrower side of the tire in the rear and wider in the front. That slightly stretched tire in the back may change the oveall diameter slightly while that other tire being "big" on the wheel could now be substantially different from the back.
I've actually thought about this alot. Anyone else?
__________________ The GT-R is harder to drift than a 997 TT or 997 GT3, therefore if you are trying to drift, the GT-R will consequently get a faster lap. Normal apexing and driving not included.
On tirerack they list the 'recommended rim width range' as well as the 'measured rim width'.. I use the specs they list for diameter, revs, etc for calculations- but as a general practice I think the rim choice should be at or +/- 1/2 inch of the measured rim width. My suspicion is that if you are within a half inch of the measured rim width for your wheel, you will not have an appreciable difference.
I just did a rough calculation for a typical 18" wheel and Porsche tire. The
sidewall will be about 3.75" tall, and assuming that's the maximum, based
on having the rim width exactly right to make the sidewall vertical, if you then
use a wider or narrower wheel by .5", effectively tilting the sidewall over,
the resulting change in rolling diameter might be around .008" or .2 millimeters,
essentially a non-issue. Compare .008" to tire wear from 10/32nds to 4/32nds
which makes .375" difference in rolling diameter.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
