Go Back   6speedonline.com Forums > Porsche (Present) > 996 Turbo / GT2
996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2.
Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 06-29-2009, 05:57 PM #31
D_Nyholm is a splendid one to beholdD_Nyholm is a splendid one to beholdD_Nyholm is a splendid one to beholdD_Nyholm is a splendid one to beholdD_Nyholm is a splendid one to beholdD_Nyholm is a splendid one to beholdD_Nyholm is a splendid one to behold
Quote:
Originally Posted by TT996al View Post
Thanks for the write up...
Just curious about the power bleeder. Is there fluid in the power bleeder or is it just air?.... reason i am asking is when you open the bleeder screw wouldn't the reservoir be empty therefore get air in the system... or would you just bleed it with 10 PSI for 20 sec and there is still enough in the reservoir so it doesn't get bubles... Hope that made sense. lol.
Also would it be just possible to gravity bleed it rather than using a power bleeder and top it off as the reservoir is low on fluid...
Thanks in advance.
There is fluid in the Motive Bleeder so you can continually bleed and not have to stop to top off the reservoir. You can use the motive just like you mentioned as well, but you do not get the full benefits. What you do when you get to the end of your bleeding process is leave the bleed screw open and tilt the bleeder until it starts to suck air. It will purge the fluid from the lines and allow you to drop the fluid down to the proper level in the reservoir.
I purchased one for this project and it made it great since the bleed screw is not the easiest reach (unless you are gumby).
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
2001 911TT GT610 PSS10 Champion RG5
Old 06-29-2009, 07:24 PM #32
Mikelly's Avatar
Mikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond repute
I do not put fluid in the motiv. Pentosin isn't something you want to put into the motiv bleeder... I also use mine for brake fluid, so I just use it to pressurize the system and rinse the gasket in the cap when done...
Do a search on Pentosin to get a better understanding why you don't want that stuff in your brake system...
Mike
UMW Tuned
K16-24 Turbos/Wastegates/5Bar FPR, Bailey DVs, VIVID Carbon Lid and SAMCO boost hoses!
Old 06-29-2009, 07:37 PM #33
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Send a message via MSN to robmd99
Just don't confuse it with Pitocin ;-)
Robert
Old 06-29-2009, 07:39 PM #34
Mikelly's Avatar
UMW Tuned
Old 06-29-2009, 08:25 PM #35
Mike
I thought Pentosin eats rubber, not plastic? I guess the gasket could wear, but I can't imagine anything else? I flush mine out when done with rubbing alcohol and always run a bit through the entire motive of whatever fluid i am using.
Old 06-29-2009, 08:30 PM #36
Mikelly's Avatar
Point is I don't want to risk mixing the two... It was recommended to me by two tuners to use TWO different MOTIV bleeders, one for clutch, one for brake, for this very reason.
Mike
UMW Tuned
Old 06-29-2009, 08:51 PM #37
Mike
Understandable. I wouldn't want that stuff in my brake lines either. I'll just use it on my wife's car first....
Old 06-30-2009, 05:50 AM #38
S4corrado996TT's Avatar
S4corrado996TT is on a distinguished road
Thank you for sharing!
2002 Protomotive PE600 K24/20G 996TT Lapis Blue
2001 Audi S4 widebody conversion AWE RSKO4 460hp
1992 VW Corrado G60
Old 07-02-2009, 07:45 PM #39
TT996al is just really niceTT996al is just really niceTT996al is just really niceTT996al is just really niceTT996al is just really nice
1-
With my Accord i bled the line by somebody pumping the clutch, holding it in, while i opened the bleeder while a friend held the clutch in.... Once the bleeder screw is closed you pull the clutch pedal up by hand and start pumping again, repeat the same procedure a few times until all the air was out of the system.... is this possible in the Porsche if i change the Accumulator to get the air out.....
Or
2-
I have access to power bleeder that i can connect to the bleeder at the bottom but using suction the pull the air out rather than what Mikelly used by forcing it out from the top..... would these both ways work or do I have to get the same bleeder as Mikelly....
Thanks in advance... never did this on a porsche so i am worried about getting air out of the system and forcing the fluid in to the accumulator, and having my dad on my a**...lol. I don't have access to the same bleeder as Mikelly so if thats the only way to get the fluid in the accumulator than i have to find one.
By the way changing the ignition was easy but i have a lot of bleeding knuckles...LOL
Old 07-02-2009, 09:18 PM #40
dtmarsh's Avatar
dtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud of
Mike
Mike, I'm surprised you just didn't do the GT2 conversion as you are more than capable. Although I think you have to drop the tranny to get it done. The stealer replaced my accum/slave under (after-market) warranty a year ago and had I been thinking I might have just had my mech do the GT2 conversion. I just don't like the variable uptake of the OEM clutch.
2001 996TT Artic Silver EVOMSit Flash EVO headers AWE Exhaust GT2 Wheels w/ MPS 235/40 ZR18 and 315/30 ZR18 7mm Rear Wheel Spacers
SS Brake Lines PSS9's Pagid Blue Brake Pads Smoked Rear Center Light 3M Clear Bra Rear Center Console Artic Silver Schnell Short Shifter Clear Side Markers EVO Hose Kit EVO Intake V1 Hardwired EVO Diverter Valves Optima Red Top Battery Ultimate Alluminum Pedals Factory 2004 Engine Installed 6/2005 GT2 Exhaust Tips Sachs Stage 2 LWFW
Old 07-02-2009, 09:19 PM #41
dtmarsh's Avatar
Mike
Ditto that. NO fluid of any kind in my Motiv. I just use it to pressurize the system.
Old 07-04-2009, 04:01 PM #42
Mikelly's Avatar
I have a couple of issues internally with my tranny (mainly a notchy first gear and sometimes second grinds on engagement down from 3rd to second). Because of that, I'm thinking of having the trans rebuild completely (and upgraded at the same time) as well as upgrading to the GT2 compontents.
Mike
Quote:
UMW Tuned
Old 07-06-2009, 01:40 PM #43
Thank you Mike again.... Clutch feels so much better and it was easy diy with your instructions.... I had made my own pressure bleeder by using a garden sprayer, bought a air tank gauge and i also put in a valve stem on it so i can use air tank to pressurize it, using JB weld i put it all together and it was air tight, and i used the wiper reservoir cap to secure it on the the reservoir after installing a little valve on it to insert the tubing. It costs less than the pressure bleeder and it was a fun playing around with it.
I got scared because when i started the car it was making noise out of the steering so it took me a while to figure out that i emptied out the reservoir for the steering in the back,stupid me..... filled that up and noise when away...... Thank you for saving me a ton of money on labour charges.
Rep points for you.
Old 10-17-2009, 11:04 PM #44
davman is on a distinguished road
This helped a great deal as I just did mine. Mine would not hold any time when the engine was off and also then starting sticking if pressed quickly, and there was a lot of vibration in the pedal (accumulator also acts as a damper and when not working will not damp vibes).
One thing to note is that bleeding is not necessary as you are not opening up the actuation circuit, only the assist circuit running off the power steering pump. No harm doing it but if it did not need doing to start with you will be right.
Old 11-04-2009, 05:56 PM #45
pcar993's Avatar
pcar993 is on a distinguished road
Great write up!
Reply
Tags
911, 996, accumulator, clucth, clutch, cylinder, diy, do, evom, fluid, gt2, master, porsche, resevoir, slave, turbo
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
