996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2.
Sponsored By Vivid Racing |
Welcome to 6SpeedOnline.com! |
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
05-15-2009, 07:50 PM
AEM Methanol Install & 24/18G dyno results
01' Porsche TT
E.P.L tuned K24/18G, 1bar wastegates, Custom Intercoolers (Bell 4" cores), 75mm TB, 72lb. Bosch Injectors, RSS Y Plenum, Ported OEM headers, Custom A.M.D. "X" Exhaust, Stg. 3 Clutchmasters clutch w/ Aasco LWFW,JIC coilovers, 19" Black Techart Formulas, AEM Methanol kit
05-15-2009, 07:53 PM
Dyno results are.....compared to baseline?
B9R BBi 996tt
Tx Mile Oct. 2009=221.212mph
05-15-2009, 07:57 PM
Dyno chart, before and after:
01' Porsche TT
05-15-2009, 08:01 PM
Can't see it clearly. What was the basline increase HP from baseline same for Torque. What were the intake temp. changes? Was this done on same dyno? What was the AFR?
B9R BBi 996tt
05-15-2009, 08:07 PM
Quote:
Same dyno, different day. I dont have the intake temps on hand but maybe Tony or Jason can post them? AFR is plotted on the chart along with hp/trq #s.
01' Porsche TT
05-15-2009, 08:10 PM
Can't see the #s, my eyes are probably going bad. Can you just put the #s in the beginning of the thread, this will help all audiences capture the big picture bro. Very nice set up BTW, good work.
B9R BBi 996tt
05-15-2009, 08:13 PM
You need a larger screen man! Jk. I will try and get a bigger pic for ya and the hp/tq #s.
01' Porsche TT
05-15-2009, 08:17 PM
After working long hours this is what happens to your eyes  LOL At least when I punch the car my eyes are ok
B9R BBi 996tt
Looks like an increase from 509 to 546 tq, and 494 to 521 hp. Correct?
Nice pics of install.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - EPL tuned
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. by Gearhead Garage
05-15-2009, 08:51 PM
How much of an increase would you see with MS109 and Meth? That will be an interesting data logging.
B9R BBi 996tt
05-15-2009, 08:52 PM
Sponsor
Don,
How long did the install take?
Is the controller required often for adjustments or do you "set it and forget it" once dialed in?
John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. (1.24 bar - 104 octane)
2002 996TT/EPL Tuned - K24/18G turbos, SpeedTech 70mm intake w/75mm Y-Pipe, 75mm TB, 60lb. injectors, SpeedTech exhaust, non-assist clutch, Greddy, PSS-9, GT3 seats
05-15-2009, 08:55 PM
John, when are you hitting your 60-130mph run? Hopefully soon. Sorry to hi-jack the thread Don.
B9R BBi 996tt
05-15-2009, 09:07 PM
2003 Porsche 911
Very nice increase Don and very nice install too!!! 30-40 hp increase seems to be the norm for these cars on Meth.
Oh yeah, John where is that 60-130? Call me if you need a P-box.
03 996TT, 24/18G's, 58lb Injectors, FVD Sport Mufflers, Custom EPL Tune w/Meth Inj.
5.99 (60-130), Best ET-11.14, Best trap-133
Texas Mile 09: 195.024 in 27.4 sec (0-186 - 23.8 sec)
05-15-2009, 09:10 PM
Quote:
Originally Posted by John D
Don,
It is pretty simple to install. Mount the pump and run a power wire to it from the battery. Then mount the controller in the center console and run a 12V, 12V turn-on, and ground to it. You will run 3 wires to the bonnet area (2 to the low fluid sensor and 1 to the pump ground). Then you will take 1 wire to the relay mounted next to the ECU to cut the power to the boost solenoid. Then you will just run the line from the pump under the car to the rear. You then install a splitter in the line and the jets in the Y-pipe (remove Y-pipe from the car). I would say 4-6 hours total. The lines are 1/4" tubing and all of the fittings are simple push in.
The controller is just like Ron Popeil would say "set it and forget it."'
I will try and get some 60-130's as soon as I find a meter to borrow from someone.
01' Porsche TT
05-15-2009, 09:54 PM
Sponsor
Art, I have never done a dedicated 60-130 run and I don't have any plans at this time, as I do not have a box.
However, TT has graciously offered use of a P box, so I will contact him and set something up. Thanks, TT!
John
Tags
18g, 996, aem, bad, dyno, graph, install, installing, kit, meth, methanol, spare, tanks, tire, turbo  |
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
User CP
Visit our Sponsors
6SpeedOnline.com
Threads:
Members:
