Go Back   6speedonline.com Forums > Porsche (Present) > 996 Turbo / GT2
996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2.
Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 05-17-2009, 01:05 PM #1
PrecisionPorsch's Avatar
PrecisionPorsch has a reputation beyond reputePrecisionPorsch has a reputation beyond reputePrecisionPorsch has a reputation beyond reputePrecisionPorsch has a reputation beyond reputePrecisionPorsch has a reputation beyond reputePrecisionPorsch has a reputation beyond reputePrecisionPorsch has a reputation beyond reputePrecisionPorsch has a reputation beyond reputePrecisionPorsch has a reputation beyond reputePrecisionPorsch has a reputation beyond reputePrecisionPorsch has a reputation beyond repute
Send a message via AIM to PrecisionPorsch
DIY: How to install 4" aftemarket speakers in our 996
So I wanted to upgrade and install aftermarket speakers in the dash and the rear. I did some research and there were a few ideas that I came across (velcro, custom brackets, etc). I know I didn't have those skills to custom make a bracket so I bought a set of Infinity Kappa 42.9i (cheap and affordable and sounds pretty good)
and hoped to figure out a way to make it work
I decided to reuse the oem speaker bracket.
Stock speaker
Started to trim off parts of the speaker
Disclaimer... of course, remember to have safety head gear before you start on this DIY
All done
Here are the tools I used to do this DIY
Metal cutter, Crazy glue and silicone glue
After this, I took off the stock speaker and test fitted my new ones. Obviously, every 4" speaker will be different in terms of their mounting points so I trimmed off part of the bracket so it fits inside the oem bracket
Before
After
I crazy glued parts the metal parts that were sitting on top of the bracket and then added silicone glue to seal the speaker onto the bracket
Let it dry for about 45 min or so and then put the speaker cover back on
Couple things to be aware of. The passenger side front dash speaker barely fit without any modifications. There is a screw on the passenger side that the speaker will sit on (at least the one I have).
The front driver side dash speaker however didn't fit. After looking at it, there is a circular plastic pipe that the speaker was sitting on.
So I took a dremel and cut out a peice and now it sits perfect.
Everything works and sounds great. I did the same to the rear speakers and they work fine so far.
Hope this helps
Edwin
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Check out Precision Porches'
Also posts as "m32"
__________________________
Reply
Tags
2001, 4, 911, 996, covers, dash, front, infinity, install, porsche, rear, speaker, speakers, turbo, upgrade
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
