Go Back   6speedonline.com Forums > Porsche (Present) > 996 Turbo / GT2
996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2.
Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 05-29-2009, 04:57 PM #61
KPG's Avatar
KPG KPG is offline
KPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond repute
Quote:
Originally Posted by WOODTSTER View Post
Currently however my track
budget is "quite lean"
OK, you win. My track budget is currently "quite non-existent"
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
TX Mile Results: 201.380mph
60-130.52sec faster thanTopGun
Old 05-29-2009, 06:10 PM #62
AtomicZ's Avatar
AtomicZ has a reputation beyond reputeAtomicZ has a reputation beyond reputeAtomicZ has a reputation beyond reputeAtomicZ has a reputation beyond reputeAtomicZ has a reputation beyond reputeAtomicZ has a reputation beyond reputeAtomicZ has a reputation beyond reputeAtomicZ has a reputation beyond reputeAtomicZ has a reputation beyond reputeAtomicZ has a reputation beyond reputeAtomicZ has a reputation beyond repute
Quote:
but you are the proud owner of a running car that is a beast
'02 GT2 - 732 rwhp - TX2K10 validated
'07 Z06 -TX Mile coming up
'08 427 Edition Z06 - #227 - stock
Old 05-29-2009, 09:44 PM #63
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Send a message via MSN to robmd99
Red, it was in their shop about 16 days I think start to finish. Timeline was just fine in my mind!
Fuel system: EVOMS Frankenfuel in tank twin pump setup with dual 044 units, Bosch relay. Upgraded fuel line, stock return line, EVOMS rails. 83lb injectors. Stock FPR
Turbo/Exhaust: Tial Hybrid GT3076R Alpha with custom billet compressor wheel,watercooled, Switzer exhaust with full cats and 02s, EVOMS race style flat collector headers with 47.5mm primaries
Tuning: EVOMSit
Intake: RSS 75MM plenum, 75MM TB, EVOMS side plenum, ported and port matched intake runners/injectors blocks, Stock Y pipe, EVOMS custom MAF housing, Hitachi MAF, Sportec twin snorkel CF airbox, BMC filter, Forge DV, EVOMS boost hoses
Heads: Custom heavy port on turbo heads, larger Ferrea intake/exhaust valves, 9K springs/retainers. Flow numbers on avg 33% better than stock.
Cams: custom exhaust grind, intake stock
Engine: Ceramic coated piston crowns, moly coated piston skirts,moly coated wristpins, flycut crowns, Arrow rods,ARP studs, EVOMS MLS head gasket, GT3RS crank,crossdrilled, shufflepinned case, boattailed mains, extra oil galleries drilled for crank center mains, Porsche motorsports bearings, GT3 oil pump, all rotating parts from the crank pulley to the pressure plate and everything in between balanced within less than a gram.
Trans/clutch: 8 Puck Clutchmasters disc, upgraded Sachs pressure plate, LWFW, associated rattles and whines, stock turbo hydraulics,stock trans
Misc: EVOMS 300M axles, B6 IC's, 6 Piston GT3 350MM brakes, Zeitronix-Boost; EGT;AFR;Pyrometer, 997 shifter, GT3RS solid motor mounts,optima 925, GT3 seats, Teq bar, bone stock exterior.....Still AWD
That about covers it...I think. If you want to see a picture of any particular internal or external part before it was installed , let me know
Kevin
You truly have a beautiful and interesting combination of parts... I am a huge fan of high reving motors hence I am smitten by the numbers and possibility of the rev limits you might achieve. Once again, congratulations on a very unique and beautiufl build.
Truly
Robert
Old 05-30-2009, 08:04 AM #64
topgun's Avatar
topgun has a reputation beyond reputetopgun has a reputation beyond reputetopgun has a reputation beyond reputetopgun has a reputation beyond reputetopgun has a reputation beyond reputetopgun has a reputation beyond reputetopgun has a reputation beyond reputetopgun has a reputation beyond reputetopgun has a reputation beyond reputetopgun has a reputation beyond reputetopgun has a reputation beyond repute
The Mod budget took over the play money , Unfortunatly this is the chance we take when we mod our toy's. Just look at the time & money Kevin & I have invested in this project. We are lucky to have the means to have these cars, let alone mod them. We were very lucky EVOMS stepped up to help us out. THANK YOU!!!
We just have to be carefull & not drink the Koolaid. I went through I lot of BS with two of my builds. (I made many mistakes myself) These are the chances we take...We all hope it works out in the end & try to forget the let downs, fustrations, dissapointments, sleepless nights, bitterness, & endless money we hide from our wifes
Old 05-30-2009, 02:14 PM #65
KPG's Avatar
KPG KPG is offline
Quote:
Tom, it is disappointing to hear that you find it necessary to hide Porsche upgrades from your significant other. Marriage is a partnership based on trust and mutual disclosure. That is why when it was time to take my car to EVOMS a few weeks ago I practiced what I am preaching. I laid it on the line to my wife, no sugarcoating,no obfuscation, no parsing of words. The harsh light of truth was shining upon me. That is what separates you and I my friend..... My wife was fully informed of my decision to have Todd upgrade my diverter valves and wastegate springs.
Old 05-30-2009, 02:25 PM #66
Prche951's Avatar
Prche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond repute
yeah right!!!!!! this is how it really went.....
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
- Concord Impresario Zenith mvmnt for sale and willing to trade for items listed in posting
Old 05-30-2009, 02:26 PM #67
sharkster's Avatar
Super Moderator
1950 Porsche 911
sharkster has a reputation beyond reputesharkster has a reputation beyond reputesharkster has a reputation beyond reputesharkster has a reputation beyond reputesharkster has a reputation beyond reputesharkster has a reputation beyond reputesharkster has a reputation beyond reputesharkster has a reputation beyond reputesharkster has a reputation beyond reputesharkster has a reputation beyond reputesharkster has a reputation beyond repute
Send a message via AIM to sharkster
I think TopGun voted on Prop8 as well....
: Performance Center for EVOMS, TechArt, HRE, Champion, Tubi, Cargraphic & Brembo
See our
Phone: 510-651-0300
Email:
*World-wide Shipping Available*
SharkWerks Porsches:
Old 05-30-2009, 03:51 PM #68
topgun's Avatar
Quote:
You know him better than I do...
Old 05-30-2009, 04:13 PM #69
PAULIEWALNUTS's Avatar
PAULIEWALNUTS has a reputation beyond reputePAULIEWALNUTS has a reputation beyond reputePAULIEWALNUTS has a reputation beyond reputePAULIEWALNUTS has a reputation beyond reputePAULIEWALNUTS has a reputation beyond reputePAULIEWALNUTS has a reputation beyond reputePAULIEWALNUTS has a reputation beyond reputePAULIEWALNUTS has a reputation beyond reputePAULIEWALNUTS has a reputation beyond reputePAULIEWALNUTS has a reputation beyond reputePAULIEWALNUTS has a reputation beyond repute
Old 05-30-2009, 04:39 PM #70
audikp's Avatar
audikp is a name known to allaudikp is a name known to allaudikp is a name known to allaudikp is a name known to allaudikp is a name known to allaudikp is a name known to all
Send a message via AIM to audikp
I AM on the list ...have been since 2006. I actually did much to help the Pbox/Dbox become mainstream around here. I set up a 6speed group buy with VboxUSA a while back. Trust me, I have always been a prolific supplier of my data....on those rare occasions I have had a running car
I shared data from some 50+ drag runs and much more GPS based data. I dont need much prodding to get the data out there. The car isnt leaving AZ without some prelim 60-130 numbers and they will get posted, good or bad. Trap speed will take a bit longer since a 1/4 mile run in the AZ Summer heat is useless. I will wait til I get home to MI or maybe sooner if we do a EVOMS group track day somewhere with a nice track.
Car look awesome man...congrats!
Along with the 60-130 numbers will you be able to log the car? Do you have access to Durametric? I would be very interested in seeing logged data!
2001 996 TT EPL / TiAL 3071 + Water/Meth (724awhp /776ft.lbs)
2001 EPL RS6 Stg3 S4 (440awhp / 479ft.lbs)
Old 05-30-2009, 05:28 PM #71
KPG's Avatar
KPG KPG is offline
Quote:
Originally Posted by PAULIEWALNUTS View Post
Sad.... I never get the carrot, just the stick
Old 05-30-2009, 05:48 PM #72
KPG's Avatar
KPG KPG is offline
Quote:
Originally Posted by robmd99 View Post
Kevin
Truly
Robert
It is definately something of a mixed breed. I will get some more numbers later in the week once I am at EVO with Todd on the dyno. I am at something of a crossroads at the moment as far as RPM is concerned. I know the motor has the BEST of everything, but how far do I push it, and more importantly, why? There is always someone faster... Do I think it could take 8500...maybe. If it pops I am back a square one. I think I will see if Todd is OK with running it from the current 7400 to 7800. I think that will gain some power with a minimum risk....
Old 05-30-2009, 09:33 PM #73
robmd99's Avatar
I think you should be safe at 7800 RPMs? I base this judgement on my car which does not have all the high RPM goodies of your motor. I have around 10K on my car since the 3.8 liter build 2 and half years ago and the max RPM is 7800. The motor is tight and still running strong, wish I could say that about my tranny! I hope this little bit of information helps you in your endeavor.
Sincerely
Robert
Old 05-30-2009, 09:41 PM #74
KPG's Avatar
KPG KPG is offline
Sincerely
Robert
Rob, that is good info. The only real weak point in my motor in relation to high RPMs are the cam buckets in my opinion. Crank,oiling,rods,springs,valves,cams etc are not a concern in my mind. Those 2 stage lifter buckets are my main concern. They are not in a GT3 as far as I know and not rated for this RPM. I did put new ones in there even though there was nothing wrong with my old ones, the old " hell, I'm in there, be stupid not to do it" theory....
Old 05-30-2009, 09:44 PM #75
Acropora's Avatar
Acropora will become famous soon enoughAcropora will become famous soon enough
LOL
Speaking of the lil lady I need to msg you this years rack schedule she agreed to. Most of them are mid-ohio but managed to get grattan, gman, road rage america and the glen on there.
You must be getting old like me wrspt pushing the engine. Was hellbent on a 150+ trap but right now it just doesn't seem that important vs grenading a motor... for now anyway...
Looking forward to seeing that monster of yours tear it up!
Protomotive 993tt 600rwhp, 132mph 1/4mile
Protomotive 996tt 880rwhp, 147mph 1/4mile
Reply
Tags
780, awhp, curve, durametric, evoms, graph, kpg, porsche, short, torque, turbo, x50
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
