Go Back   6speedonline.com Forums > Porsche (Present) > 996 Turbo / GT2
996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2.
Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 06-01-2009, 11:07 AM #1
tvurt's Avatar
tvurt will become famous soon enoughtvurt will become famous soon enough
Send a message via MSN to tvurt
Dial gauge, adjusting wastegates
I am getting all the tools together to properly adjust the "bypass flap control boxes" (lol no wonder I could not find wastegate in the factory shop manual)
Going to be using my motiv for pressure, and adjusting each wastegate separately.
Pressure to 12 psi for the start of movement.
will this do the job for a dial gauge?
http://toolusa.amazonwebstore.com/1-...source=froogle
Thanks, Tom
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
2003 996TT K24/18g + lots of stuff
2008 335xi
Old 06-01-2009, 11:58 AM #2
Danyol's Avatar
Danyol is just really niceDanyol is just really niceDanyol is just really niceDanyol is just really niceDanyol is just really nice
Been There!
Let me know if you have any questions (note I have standard K24s on an X50; Porsche spec 4mm for 0.5bar)
ID:	98019   Click image for larger version
ID:	98020   Click image for larger version
Name:	Wastegate Adjusted.jpg.jpg
ID:	98021   Click image for larger version
Name:	Wastegate Table STD.jpg
'03 TT X50, KW V3, Eibach sways, Champion RG5, SpeedTech 2.5 Crossflow, 997 shifter, Ecliptech Shift-I, Custom CARPuter
Old 06-01-2009, 12:07 PM #3
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
Send a message via Skype™ to ShokWaveRider
How do you plan on adjusting 8psi wastegate actuators to 12psi....... ? Personally I do not think you need the gauge. Simply rig up a pressure system from your compressor with a low pressure valve and set to your desired cracking pressure and adjust away.
SWR
Thanks, Tom
Blue 2005 TT S - 200 Cell MaxFlo Exhaust, 1 BAR Wastegates, SofTronic Flash, Forge DVs, Custom Headers, Aquamist HFS-6, 3M Clear Bra
2006 Saturn Vue, Lotus Twin Turbo V8; ImpConcepts Mods, 550hp (Sold), Ferrari 328 GTS; Stock (Sold), Audi S4 Twin Turbo 350hp (Sold), Sunbeam Tiger V8 Stock (Sold) The rest don't fit!
"Arguing with an Engineer is like rolling in the mud with a pig. Just don't forget the pig likes it!"
Old 06-01-2009, 12:17 PM #4
What is the Max you can dial into the stock K24 Actuators? Anyone Know? The chart actually says 10psi., is that real?
I would love to replace the complete units with nice aftermarket ones but I have read so many bad things about rods breaking etc., and I do not want to destroy mine to do the spring mod.
I wish I could just find some brackets. Then I could source some aftermarket actuators and go from there. I was thinking of replacing them with 8 - 14psi adjustables. They are relatively inexpensive but I cannot find any brackets for the K24s.
SWR
Quote:
Originally Posted by Danyol View Post
Been There!
Old 06-01-2009, 12:21 PM #5
Danyol's Avatar
SWR, "Real" - yes with the factory adjustment; I created the charts with experimental data on a calibrated gauge.
Old 06-01-2009, 12:31 PM #6
Thanks, so If I connect up my compressor and set it for 10psi, then adjust the screws/nuts till they just crack each side I should be OK then. Am I understanding you correctly?
OR
Adjusting them to the spec (0.5 bar = 7.35 psi) are you saying gives a READING ON THE BOOST GAUGE IN THE CAR of 10psi.
Just confirming? I think I read you correctly the first time.
SWR
Old 06-01-2009, 12:41 PM #7
Danyol's Avatar
You connect directly to the wastegate, set the regulator to 7.35 psi, adjust nuts for a 4mm movement on the dial gauge (from it's resting position). Adjust the two turbo wastegate responses the same way.
The boost gauge is not relevant to the adjustments.
Old 06-01-2009, 12:44 PM #8
Gotcha!
So if I was adjusting for 10psi same thing but for 10psi not 7.35. do you know how high tey will go?
Regards, and thanks for the tutorial.
Ian
Old 06-01-2009, 01:18 PM #9
Danyol's Avatar
The physical limit for the stroke appears to be about 11.5 mm. On my car at least, this was at 10 psi. Personally I would adjust to an intermediate point rather than a limit, like Porsche specs it.
Old 06-01-2009, 01:31 PM #10
tvurt's Avatar
Ah ShokWaveRider I have 1 bar wastegates on hybrid K24's so 12 psi should not be a problem.
Thanks for the pics Daynol. Is that the same tool that Google found for me?
Tom
2008 335xi
Old 06-01-2009, 01:38 PM #11
Danyol's Avatar
Tom
The dial gauge is a standard gauge with a magnetic base. The rest of the setup is homebrew - Home Depot & Grainger
Old 06-01-2009, 02:01 PM #12
tvurt's Avatar
Thanks Danyol, homebrew I can handle!
2008 335xi
Old 06-01-2009, 02:15 PM #13
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
Send a message via AIM to Chuck Jones
If you look at the post ARD put up sometime back, he shows pictures and a description of his homemade device that he used to adjust mine to 8.75 psi...and I'm running a steady 1.1-1.2 bar with the UMW wastegate kit. He hooked it up directly to the wastegate.
2002 996TT X50, Midnight Blue; Europipe stage 1; 18" CCW CNC Wheels; EVO DV's; EVO GT2 headers; UMW tune and Wastegate kit; Sachs GT2 clutch kit; 997 shifter; factory aero and CF interior.
1987 930S factory slantnose cab; Guard's red all original (till it comes back from the builder on 5/5, then I'll have to change my description of "all original")
1999 996 C2 Iris Blue; caught fire and burned 9/07.
Old 06-01-2009, 02:38 PM #14
tvurt's Avatar
Good reference Chuck, I think I read every thread on this forum regarding wastegates, except that one, which is great.
Wastegate actuator discussion
Tom
2008 335xi
Old 06-01-2009, 02:43 PM #15
Tom....I don't recall if it was this forum or Rennlist...but Adam (ARD) definitely knows his stuff....and his Rube Goldberg contraption was exactly what it took to dial the wastegates in perfectly balanced....not like some of the guys do by measuring 10mm from the end of the lock nut to the tip of the rod. driver and passenger side rods diiffer in length.
Reply
Tags
996, actuator, adjust, adjusting, car, custom, gates, lotus, turbo, waste, wastegate, wastegates
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
