Go Back   6speedonline.com Forums > Porsche (Present) > 996 Turbo / GT2
996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2.
Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 06-24-2009, 10:00 PM #1
BlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to behold
Puzzling meltdown at the dragstrip...
Went to the dragstrip tonight, and cant figure out what went wrong.
55 minute trip to track, 82 degrees.
1st run, turned PSM 'off'. Got off the line and spun all the way to redline in every gear with NO BOOST. Felt like the engine was revving properly but the car wasnt really pulling at all in any gear. No grab. Hit redline very quickly in every gear with no real boost. Time was terrible. Smelled like burnt clutch. No fluid leaks. Did a few test runs on nearby road with PSM 'on' and had no issues. Clutch engaged well. Boosted to 1.1 Bar, and pulled like it should.
2nd run. PSM 'on'. A little trouble off the line but car felt like it was hooking properly, came in with 12.51@122 mph. Decided to call it quits, not push my luck.
Was this a sign of an ailing clutch or did i just overheat it during the first run and it wouldnt grab? Seemed to work on 2nd run and ok on the way home.
BTW, Im supposedly running 575hp on a stock clutch. Is this inadequate for drag launches??
Thx for any input.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
Old 06-24-2009, 10:42 PM #2
vntperformance's Avatar
vntperformance is a splendid one to beholdvntperformance is a splendid one to beholdvntperformance is a splendid one to beholdvntperformance is a splendid one to beholdvntperformance is a splendid one to beholdvntperformance is a splendid one to behold
Send a message via AIM to vntperformance Send a message via Yahoo to vntperformance
Sounds like you glazed the clutch from heat; should have waited 15-20mins between runs and tried again but with a softer launch.
~1995 Toyota Supra Hardtop|6MT [Renaissance Red]
-JRE/Pro Port Built 2JZ-GTE, GSC, Fikse, OS Giken, AEM and all the fixings. {Tuned by Brad Brooks}.
-2001 Porsche 996TT [Seal Grey|6MT] "FVD Level 3"
-2008 Toyota Camry SE [Magnetic Grey] "Wife's Car"
Old 06-25-2009, 11:55 AM #3
MBailey has a reputation beyond reputeMBailey has a reputation beyond reputeMBailey has a reputation beyond reputeMBailey has a reputation beyond reputeMBailey has a reputation beyond reputeMBailey has a reputation beyond reputeMBailey has a reputation beyond reputeMBailey has a reputation beyond reputeMBailey has a reputation beyond reputeMBailey has a reputation beyond reputeMBailey has a reputation beyond repute
Sounds like clutch slip to me.
I mentioned to you earlier that it would not last long at that power level. It will only get worse from here out. I would start looking for a stronger replacement. Keep in mind potential future mods you may want to do. IOW, if you even think you may go with more power mods in the future get a stronger clutch than you currently need. The cost difference in the clutches is dwarfed by the labor cost and down-time of doing this job more than once.
2003 996 TT EVOMS GT740R = Tial A28s + 75mm Throttle Body, IPD Plenum, EVOMS Stage 4 XR Clutch, Clubsport Headers, Pulley, & ICs. BBI Plasma Coil Packs, GT-3 CF Sport Seats, HRE C93, PSS10, Girodisc Rotors, B&M SSK. 6.31s 60-130. 198.4 MPH Standing Mile
2004 Cayenne TT
Old 06-25-2009, 12:28 PM #4
tvurt's Avatar
tvurt will become famous soon enoughtvurt will become famous soon enough
Send a message via MSN to tvurt
By no boost do you mean not seeing any on the indash display, or not feeling it?
2003 996TT K24/18g + lots of stuff
2008 335xi
Old 06-25-2009, 01:12 PM #5
Angry
I didnt feel any boost. Car boosted better after it cooled down. Still not grabbing well at low rpm's in 1st gear.
I understand a stock clutch may have problems when stressed on a dragstrip with a high HP car, but then why wouldnt FVD include a better clutch with the Stage 4 package to begin with? Only seems right to put in a clutch that can handle the engine mods. Car only has 26,000 miles.
2003 996 TT - FVD Stage 4 - current
2008 Hummer H3 - Inferno Orange - Winter Beast
1993 964 C4 Triple Black - sold
2003 BMW M3 - all stock - sold
2002 WRX - sold
1987 944 Turbo - sold
Old 06-25-2009, 01:28 PM #6
It all depends on what the original owner wanted to spend. Many folks put in higher hp kits and just wait for the original clutch to fail before changing. Many kits include a stronger clutch but you can opt out of it if your want to save $.
2004 Cayenne TT
Old 06-25-2009, 06:48 PM #7
Monster231 is on a distinguished road
Clutches can go bad fast
Depending on the driving habits of the prev. owner. 26K is plenty of time to screw it up. I have seen clutches fail after 5K of bad driving.
Old 06-25-2009, 07:10 PM #8
+1 I have seen that too.
Additionally, I had a stage 1 clutch that was excellent for my flash/intake/exhaust K-16 setup which was about 440-450whp. It held thru my GT610 but started slipping within one week of putting on a race gas gt660 setup (gt660R = roughly 560-570 whp).
2004 Cayenne TT
Old 06-25-2009, 09:43 PM #9
So at my power level, occasional dragstrip fun, 4-5 DE's per year, and plenty of Daily Driving - Im thinking Stage 3 Clutchmaster or Sachs.... Triple Carbon sounds too tough for street duty. Any thoughts?
2002 WRX - sold
Old 06-25-2009, 09:55 PM #10
I would agree with that as long as you are sure you will not go higher than you currently are.
2004 Cayenne TT
Old 06-25-2009, 11:19 PM #11
onelove's Avatar
Premium Sponsor
onelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond reputeonelove has a reputation beyond repute
Send a message via AIM to onelove
Sounds like a clutch for sure. Stage 3 should be perfect, if you plan on racing the car a bit more I would suggest a triple carbon clutch, it's not as bad as it's made out to be and when combined with the fact it already includes a flywheel, it's competitively priced when compared to a stage 3 with new dual mass from Porsche.
SWITZER Exhaust Specials : PM for more info
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Wes Bourne
phone: 407-277-8423 x226
aim : onelovewcb
email:
2003 996TT K24-18G /
2007 BMW X5 4.8i / 2003 BMW M3 SMG
Old 06-26-2009, 02:04 AM #12
Terminator's Avatar
Terminator is on a distinguished road
BTW, Im supposedly running 575hp on a stock clutch. Is this inadequate for drag launches??Thx for any input.
This is a statment of the year. . Yes!
"Life is far too important to be taken seriously." Oscar Wilde
996T-X50, Flash, CarGraphics Pipes, PSS10's
944 Turbo S, (farewell my lovely)
Aprilia RSV Mille R Factory
Old 06-26-2009, 03:00 AM #13
Old 06-26-2009, 05:42 AM #14
Sounds like a ridiculous question, i know, but why the heck wouldnt FVD add in the right clutch to go with the kit??? Only seems to make sense. You spend 35K on upgrades but cant put the power to the wheels!!? Just to save a few bucks? Buyer beware, I guess. My fault for not checking it all thru before buying it.
Whatever. I still wouldve bought it in a heartbeat. Car is unreal. I just still have no idea how to tame it.
2002 WRX - sold
Old 06-26-2009, 08:01 AM #15
ttboost's Avatar
2003 Porsche 911
ttboost has a reputation beyond reputettboost has a reputation beyond reputettboost has a reputation beyond reputettboost has a reputation beyond reputettboost has a reputation beyond reputettboost has a reputation beyond reputettboost has a reputation beyond reputettboost has a reputation beyond reputettboost has a reputation beyond reputettboost has a reputation beyond reputettboost has a reputation beyond repute
When you buy a nitrous kit with a 200 shot, Do you think you are going to get a clutch with your kit? If you know you are going to make 1-1/2 to 2 times the HP of stock, you CANNOT expect your stock clutch to last. My stock clutch lasted 800 miles after my first K16 flash!!!
Buy a good clutch and enjoy your car!!!
03 996TT, Bored and for sale already?
5.99 (60-130), Best ET-11.14, Best trap-133
Texas Mile 09: 195.024 in 27.4 sec (0-186 - 23.8 sec)
Reply
Tags
2008, camry, drag, dragstrip, runs, se, strip, v6
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
