996 Turbo / GT2Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2. Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
and you need really small hands...it is very tight in there...LOL
Bill
so your telling us you have very small hands? small feet too? what else?
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Concord Impresario Zenith mvmnt for sale and willing to trade for items listed in posting
My DVs are made by Bailey, and are billet units. I've pulled them twice in 2.5 years, but never seen an issue with them functioning.
This is good to know, and sorry you're going thru this Chris... However, I've never been told to pull and inspect DVs every 6-12 months. That seems a bit much, if you have good quality units.
Mike
__________________ UMW Tuned K16-24 Turbos/Wastegates/5Bar FPR, Bailey DVs, VIVID Carbon Lid and SAMCO boost hoses!
Dennis...that really added to the thread...thanks for your insight
Chris has little feet as well, so don't feel so bad.
UMW 2C & LWFW - X73/light suspension work - EP2Loud - GT2 brakes and body work -
Custom 996turbo/997GT2/997GT3RSR tranny - and probably some other **** I forgot.
About 6 weeks ago I blew another driver side turbo, at first it was a coincidence that it was the 2nd failed driver side turbo but after some investigation we have found a probable significant contributor to the problem.
A few years ago I had the dealer install some aftermarket DV's along with the the GIAC stage 2 mod, the receipt reads "forged dv's", after pulling the engine to do an inspection of all oil feed lines, etc, we found that both DV caps were about one turn from coming off completely. "A one year old would have been able to remove them" my tech says. This has probably been robbing me of power as well as damaging the turbos
The next question took me by surprise-
Tech: when's the last time you inspected them?
Me: They need to be inspected?
Tech: Yeah, every 6-12 months
Me: Uhhh...never, had no idea they needed to be inspected.
Anyone else ever hear/read about checking the diverters on a regular basis???
Another lesson learned is to check what you bought, I didnt have forged, I had a lower quality evos (not to be confused with EVOMs, but I think there may be or have been a relationship). Appearently the evos are infamous for the caps coming loose
Probably a good time to check your DV's, check the springs and diaghrams, make sure the caps are tight and make sure you got what you paid for.
The fact that the receipt reads "forged dv's" and you found out that they aren't makes me think you should be going to the dealer about this issue and DEMAND that they fix it at their cost. Also let them know that they never told you that routine maintenance was required with these.
Current Cars:
-'72 RS Clone w/964 3.6liter, approx 2,300lbs
looks like turbo to cats and turbo oil sump, the lever is connected to the wastegate actuator rod which goes to the wastegates. Diverters are on top of the motor, left side just right of the intake. See if one of us can find a pic for you.
Quote:
Originally Posted by Macster
I mean I believe you when you say DV's on top of engine. Just wondering that this a picture of?
Sincerely,
Macster.
I'm heading back there this summer, they should remember me from 3-4 years ago :-) I hear you though, this does suck, but the lesson is to make sure you get what you buy :-/
When I went to EPL for flash and diverters, they took the time to explain the options, performance, and maintenance implications of each type. They clearly told me about the need for regular maintenance cleaning and lubrication of the forged DV's approximately every 15,000 miles. Work with a first rate tuner shop like EPL.
I'm wondering if folks are confusing the fact that a DV might be marked "forged" rather than "Forge". I don't know if knock-offs are using the term to make folks think they're getting a Forge unit. If you examine the construction of a number of them, most of which are made in China and labelled by various distributors, they are all billet, they unscrew at the top, have a 90 degree swivel hose connection at the top, and they have the piston and spring inside. One iteration has some sort of rubber O ring inside which is supposed to make a better seal, but I see that as a potential point of failure and need for periodic cleaning and lubing to keep the O rings from wearing.
As much as I hate the thought of it, I'm going to have to go pull mine, take a look, and use the time to service them. It's been a good 15K miles since I installed them.
2002 996TT X50, Midnight Blue; Europipe stage 1; 18" CCW CNC Wheels; EVO DV's; EVO GT2 headers; UMW tune and Wastegate kit; Sachs GT2 clutch kit; 997 shifter; factory aero and CF interior.
1987 930S factory slantnose cab; Guard's red all original (till it comes back from the builder on 5/5, then I'll have to change my description of "all original")
1999 996 C2 Iris Blue; caught fire and burned 9/07.
