996 Turbo / GT2Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2. Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
I have about 4000 miles on my ATS Triple. It is a lot less grabby than the first 800 miles but still engages at the top of the pedal travel. It is also very hard to launch from a start but I am getting much better at it. Since I only drive my car once a week, I need to relearn the clutch every time Saturday morning before I match her up against other cars. I am interested in lowering the engagement point, but will wait to hear the outcome from a few others.
Thanks for the info!
I think this "forced break-in" is what you need. It "warps" the discs thus makng them appear "thicker" which in turn allows your pedal to grab sooner/lower...I bet if you do this excercise, it might be better?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on 6SpeedOnline!
__________________ 03 996TT, 24/18G's, 58lb Injectors, FVD Sport Mufflers, Custom EPL Tune w/Meth Inj. 5.99 (60-130), Best ET-11.14, Best trap-133 Texas Mile 09: 195.024 in 27.4 sec (0-186 - 23.8 sec)
Sean if you put your car in the garage when you do this, it will make you cool and add 15 HP to the rear wheels. Trust me on this. Just face the car in, and close to the wall when you try it. I promise.
2002 996TT SOLD - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
i said this long time ago!!!!!! i told you guys put it in 2nd or third and launch the car!! it will make the disc warp a little do that 4- 5 times and should be good!! man if you guys only listen before!! mine feels like 95% stock now
To the world you might be just one person...but to one person you might be the world
911tuning.com + Protomotive.com = 724.73whp 6.0 60-130 / 10.83 @138.53
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ">
You have a triple disc?
yea i put it in 2 months ago. The best thing i ever did! hands down..
Me and Todd from Proto talked about the breakin procedure for hours till i got it perfect.
He actually siad the fastest way was to use a trailer and Load it on ion 3rd gear slipping it and do that 3-4 times.
I guess you can use a really steap hill?
the only reason i bought it was because of DR_JITSU he siad straight out.. "It holds like a Mother!! but its a bitch to drive!"
And i love it!
I had zero issues with my ATS clutch. I actually let other people drive my car to see how well it works. I think Chris (roadsterdoc) can shed more light on his driving experience. I did not break my clutch in, I allowed Akram to do it so I can not say what is was like before he broke it in. I hope this helps.
Robert
Also for those of you with true carbon based clutches (ATS is Hybrid) you also will need to do a quick slippage on a dyno before tuning if the car hasn't been driven prior. Carbon with no heat = a bit of slippage but it literally take less than a few blocks of normal driving to get it to operating temperature.
__________________ SWITZER Exhaust Specials : PM for more info
Wes Bourne
phone: 407-277-8423 x226
aim : onelovewcb
email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
2003 996TT K24-18G / 2007 BMW X5 4.8i / 2003 BMW M3 SMG
Wes,
I just got my ATS triple carbon from VR. I need to send it to Carbonetics in Cali to have it further modified. Any other recommendation of breaking it in? Not quite sure what you mean about slippage on dyno, can you be specific?
Art
Quote:
This is something the Supra guys were doing 8 years ago when the RPS Carbon/Carbon first came out. I would NOT recommend doing this on a NON-Carbon clutch. You will have NO clue when enough is enough and can cause more wear than desired. On a Carbon unit, all you're doing is heating that Carbon up and making it grabbier...in the process helping to "break it in" a bit.
Peter
__________________ 2009 Nissan GT-R Super Silver/Black/Premium To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. / 7.74 60-130 / 181.7 mph at the TX Mile
Wes,
Art
The carbonetics/ATS triple is actually not a true carbon/carbon material. It's carbon based impregnated with silicon and various other metals. One needs to be careful about overheating it, because while it does have carbon in it, it is still prone to warping and can be overheated. This clutch is rated to 700whp in a drag racing environment per Carbonetics specifications, if I recall from recent posts you're looking to exceed this rating by quite a bit ? You may be good for a bit, however as the clutch wears you are going to deal with significant wear problems as well a decreased engagement window, a characteristic common to these styles of clutches which use multiple plates while using the factory hydraulics which limit your flexibility for adjustment.
With a Carbon/Carbon unit, say you let your car do a complete cool down prior to dynoing it. The carbon/carbon grabs better with heat, so in order to get it to operating temperature (since it's strapped down and driving around the block is not an option) you need to use the dyno brakes to get a bit of heat in it, usually with a quick slip or two in third gear. Otherwise you'll see some nice spikes in your graph on the first pull. After the first pull the clutch will obviously have enough heat in it so the second one will work. Most wouldn't notice the dips, but when you're dynoing 1,000-1,500hp cars frequently these small steps have to be taken into account.
Wes Bourne
aim : onelovewcb
Wes which clutch do you have in your 24/18 car? How well does it hold the power & whats the engagement like?
In both of our cars we run the Tilton triple. There isn't a 996 I've ever heard of that exceeds the torque capacity of the clutch (1400tq) while remaining completely drivable in street duty in terms of clutch modulation and engagement point. The main reason being we anticipated making over 700whp (even on the K24/18gs) and wanted to upgrade to larger turbos down the road and frequently drag race without having to change the clutch. We've tested many different combinations and felt there was a big gap that needed to be filled so we developed something to fill the gap.
Most K24/18G cars and similar turbos can get away with the Clutchmasters Stage 3 and be very happy while remaining drivable in my opinion and be fine, if you're pushing past that the ATS/Carbonetics is the next step but the threshold of additional power is not much more based on manufactures ratings so guys running built engines or 30s or larger may overpower it.
Wes Bourne
aim : onelovewcb
Great Info Wes!! you have always been a world of knowledge on this board! Cheers!
