Low Profile Car Lifts, Anyone got a lift in their Garage?
I had the LiftMaster "Jack Shaft" side mount opener installed in my garage. The tracks were re-routed so the door, when fully open, is only a few inches from the ceiling. My lift is a four post that I got from Greg Smith Equipment (gregsmithequipment.com) out of Indianapolis. Works great and I can park the Turbo on top and my wife's Carrera below. Get the "Bridge Jacks" so you can lift the car while on the ramps. And, have them convert the jacks to pneumatic so you can use your compressor to jack the car up rather than using your arms to pump the jacks! There isn't much you can't do on your car with this setup in a home environment. A friend and I installed two of them in our garages in one Saturday.
I need a LOW RISE or MID RISE Floor mounted Lift with no posts. But all the ones I have found have 53" Beds and the Porsche has 54" on center jacking points.
This is easily the coolest lift install I've ever seen (and what I plan to do when I move to the burbs).
It may solve your problems:
http://www.garagejournal.com/forum/s...ad.php?t=35433
Pics? I was walking around my garage yesterday wondering if I could move the rails up like what you mention and add the side mount opener. Glad to know it can be done. I plan to add some garages in the future, but that's a couple of years away and I could use a lift now.
How tall is your ceiling?
Four Post Lift
You're right, it can be tight in an 8 foot garage. Mine has 11 feet to the ceiling. My friend has an 8 foot ceiling and we put one in his. He can put his 930 up on it and still have a few inches to spare. It's tight but it works. With the pneumatic jacks and the variety of safety stops on the lift, he has been able to find safe levels to do everything he has wanted to do. Obviously, any type of SUV would be totally out of the question in his setup. Hope you find an acceptable solution. There's nothing like having your own lift. Even if all you're doing is polishing or waxing the car. Saves my back!!!
totally agree on putting a proper set up in the garage for those who have the motivation and option. Saves money, know the jobs done right, and it's so much fun!
I use a double platform alignment hydraulic scissor lift . Lift the car up from the wheels or sideskirts points. up on wheels is great when the work doesnt require taking off wheels. dont have an alignment facility hooked up to it but the flat platform allows for manual alignments.
it recesses into the ground fully flat which is great for low profile cars. Downside is cant park another car under it but looks like this garage wouldnt allow for that anyways.
Unfortunately the ground work is almost as expensive as the lift. This type of lift isnt the cheapest but over time, it makes more than it's money back.
Here's the first 5 pics. Shows the side mount door opener and the re-routed tracks. A side benefit is the cleaner look of the garage without the opener hanging in the middle of the ceiling.
These three pics show the lift from the outside and the two "bridge jacks" with the arms extended fully and then fully retracted. Best thing I ever did. Made my 2 1/2 car garage into a 3 1/2 car garage.
True enough. I think I could take the tranny out with this lift. Certainly not a motor. I can do anything related to suspension etc. My other thinking when I got the 4 post lift was that I wanted to store two cars during the winter in Michigan. And, I did not want my four wheels hanging on the suspension for months at a time. I guess you have to really think about how you're going to use a lift when you're doing your research. It's rather hard to undo once you have the lift in the garage.
Not sure if this will work for you but it is the one I am thinking about!
http://www.dannmar.com/dannmar-produ...ts/maxjax.html
Stacy
Stacy
Stacy
Stacy
I would like a flush mounted floor system of some sort that fits the 54" points on the Porsche. I am not opposed to sinking it into the floor a few inches.
Unfortunately I am really limited as I have a 2 car garage (as opposed to 2.5) and that 8' headroom is a limitter. I also want to roll around underneath so a conventional Scissor Lift is out.
I would want a single pour, rebar reinforced concrete base, something on the order of a cubic yard or two, that is contiguous between the two posts- with mounting J-bolts tied to the rebar. In new construction, just dig a bit of a trench, set the steel, fixture the Jbolts, and fill the trench. Then when the floor is poured later the bolts will stick up. On an existing floor, I would concrete saw out a section, then dig down, undercutting the exisitng floor a bit. Steel then pour.
I just do not feel comfortable drilling holes and using expansion bolts on something like this...
Shok's situation is difficult. An 8' ceiling in a garage seems strange. That's awful low. I would expect 9 to 10 feet at least. He might still be able to use a 4 post lift but he would not be able to lift the vehicle very high at all. But, he could still get under it to do some work. For someone who makes a living as a technician, I would think a two post with adequate height would be a must. I think my four post is a nice compromise between extra vehicle storage and having the ability to work on the cars (at least to my limited level of capability). But, without adequate ceiling height it would be a serious compromise.
Then fix/reroute your garage door. THEN, with new measurements, decide which lift to get.
