Go Back   6speedonline.com Forums > Porsche (Present) > 996 Turbo / GT2
996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2.
Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 09-19-2009, 05:15 AM #31
Speedy996tt is on a distinguished road
Quote:
Originally Posted by Boost Logic View Post
The F-Con is piggybacking the stock ecu in Justin's car. We will be using this setup for the higher horsepower cars in addition to Motec for race applications. For lower hp street applications we will be flashing the stock ecu.
Would I be able to remove the fcon vpro I am using in my gs300 (twin turbo vvti 2jzgte) and use it in my 996tt?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
Old 09-19-2009, 06:51 AM #32
vrybad has a spectacular aura aboutvrybad has a spectacular aura about
I'm curious about the torque curve.
Most of the modded TT's using 18g's and the new Alpha 28's are making 500+torque at 3500rpm or lower, which is considerably earlier than this setup.
Granted your turbos may have greater top end capability, but is there any way to ramp torque in earlier?
For the street, where most drive their cars, an earlier torque curve would be an advantage.
Otherwise, nice results, and looking forward to seeing the boost cranked up.
here is the pump fuel + water injection dyno(at 19-20psi). All of this is done with a STOCK exhaust since I am a wuss and I like stuff to be quiet. Unfortunately, I still wanted 600whp on pump fuel(it made 557 at 17psi without the water injection). If I put straight pipes on it(which I do have), or at least a free flowing exhaust, I think I can make another 20-30. I also believe I can make another 20-30 with upgraded intercoolers. Mine are stock. This was to showcase only the turbo system which I have been testing for about 6 months now.
Let's recap.... the car has the following
Boost Logic Bolt On Turbo System
Stock engine(upper and lower, or lefter and righter)
1000cc Injectors(tba)
Standalone
stock ECU
Stock intercoolers
Stock Exhaust(2nd cats removed)
Stock Fuel pump
Stock Fuel Lines
And here is the dyno on 109.... nothing spectacular as I don't want to push the car too hard
Don't look at the AF as it wasn't hooked up to the car.
Justin
2002 QS MR Z06(sold)
60-130 6.89sec Performance Box
A drop of water has nothing on me
when it comes to being shallow!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Old 09-19-2009, 08:13 AM #33
Dr_jitsu's Avatar
Dr_jitsu has a reputation beyond reputeDr_jitsu has a reputation beyond reputeDr_jitsu has a reputation beyond reputeDr_jitsu has a reputation beyond reputeDr_jitsu has a reputation beyond reputeDr_jitsu has a reputation beyond reputeDr_jitsu has a reputation beyond reputeDr_jitsu has a reputation beyond reputeDr_jitsu has a reputation beyond reputeDr_jitsu has a reputation beyond reputeDr_jitsu has a reputation beyond repute
The V Pro is one of the (IMO....incredible resolution) best stand alones out there....why is it being used as a piggyback???
2002 Porsche GT2 with GT 30's Tuned by Protomotive. 60-130 Street Tire Champion Tx2K8 and Tx2K9.
2004 BMW Individual M3: BHS Supercharged Stage 2. 8.59 60-130
2009 Mercedes E350
2004 Porsche Cayenne TT.
Old 09-19-2009, 09:11 AM #34
Boost Logic has a spectacular aura aboutBoost Logic has a spectacular aura aboutBoost Logic has a spectacular aura about
Quote:
The FCON ECU unit itself would be the same but the major expense is contained in the custom harness needed to install the unit.
Zohair Jaffery
512-371-9960
Old 09-19-2009, 09:50 AM #35
art4iza's Avatar
art4iza has a reputation beyond reputeart4iza has a reputation beyond reputeart4iza has a reputation beyond reputeart4iza has a reputation beyond reputeart4iza has a reputation beyond reputeart4iza has a reputation beyond reputeart4iza has a reputation beyond reputeart4iza has a reputation beyond reputeart4iza has a reputation beyond reputeart4iza has a reputation beyond reputeart4iza has a reputation beyond repute
Welcome Boost Logic!! Looking forward to see the results.
B9R BBi 996tt
Tx Mile Oct. 2009=221.212mph
Old 09-21-2009, 02:46 PM #36
justinn's Avatar
justinn will become famous soon enoughjustinn will become famous soon enough
Send a message via AIM to justinn
If he has fcon vpro, he still utilizes his oem ecu. Hks fcon is somewhat of a piggy back...
Kinda true, let me clarify.
The VPro is being used only as a piggyback as it pertains to the drive by wire, traction control, and other emissions related hardware. It has 100% control over all of the engine parameters as they pertain to ignition timing and fueling. The stock ecu controls 0% of this now. This allows me the feature of having an emissions station plug into the OBD port and get all of the feedback that they need. I can also still troubleshoot car related issues via the OBD port. So it is a win-win situation. I have also gone 100% speed density(eliminating the MAF altogether), just to prove it could be done
Justin
Old 09-21-2009, 02:49 PM #37
justinn's Avatar
Quote:
Originally Posted by robmd99 View Post
Justin
Good luck and we are all looking forward to what you can add to P car community!
Hook em Horns
Robert
Thank you sir!
Looking forward to add our bit of knowledge to the mix
Justin
Old 09-21-2009, 02:50 PM #38
justinn's Avatar
With some minor tweaking internally, yes. THe majority of the goings on happens in the adapter harness itself.
Justin
Old 09-21-2009, 03:00 PM #39
Quote:
Justin
And how much would this adaptor harness run?
Old 09-21-2009, 04:18 PM #40
justinn's Avatar
there is no set pricing as of yet, but I am pretty sure it will be an entire package as there is alot of work that has to go into it to keep the stock ecu happy. It will also have to come with a base map that is a few hundred hours in the making
as of right now, this is an "in house" install only
Justin
Old 09-21-2009, 08:29 PM #41
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Send a message via MSN to robmd99
Speed Density..... I like the sound of this!
Robert
Old 09-24-2009, 01:28 AM #42
medici78 is a splendid one to beholdmedici78 is a splendid one to beholdmedici78 is a splendid one to beholdmedici78 is a splendid one to beholdmedici78 is a splendid one to beholdmedici78 is a splendid one to beholdmedici78 is a splendid one to behold
Hey, Justin! It's Isaac from El Paso. Damn, you guys are making me want to get back into a 996TT. Just wondering how much power you think is possible on the 91 octane piss we get out West.
Old 09-24-2009, 09:20 AM #43
justinn's Avatar
Hey Isaac!
I would say if you want to use the WM combination, that 575-600whp is still very doable, even out there. If you have intercoolers, and a free flowing exhaust, well over 600 is achievable.
Although I despise alky injection as a tuning crutch(and refuse to tune "against" it, It does alot in hot climates and where questionable quality fuel is available.
Talk to you soon.... btw, what's your latest project?
justin
Old 09-24-2009, 11:36 AM #44
2001 Porsche 911
Steve Theodore is just really niceSteve Theodore is just really niceSteve Theodore is just really niceSteve Theodore is just really niceSteve Theodore is just really nice
Send a message via AIM to Steve Theodore
Boost Logic has always been a truly stand up shop in the Supra world, and it's awesome to hear that they are expanding into the world of Porsches (and GTRs). I'd wish them luck but know they won't need it once people start experiencing their great service and products. Well done!
Steve Theodore
2001 Porsche 911 Turbo
ex-1993.5 Toyota Supra TT hardtop
ex-2004 Chevrolet Corvette Z06
Old 09-24-2009, 11:45 AM #45
Almo's Avatar
Almo has a spectacular aura aboutAlmo has a spectacular aura aboutAlmo has a spectacular aura about
Great news!
2002 Porsche 996TT - K16/16G Turbos
2003 Sonic Blue Cobra - To date, the quickest/fastest non-ported non-sprayed pullied Eaton 03/04 Cobra on the planet. 10.69 @ 128.59
Reply
Tags
24, 911, 964, 996, 996tt, boostlogic, dyno, gt2, installed, intercooler, k16, kit, picture, porsche, turbo
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
