996 Turbo / GT2Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2. Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
I've used OS Giken in my s2000 and NSX, one of the best options for street/trackday JDM cars. There are a lot of different specs, not sure which is offered for Porsche. went with the Quaiffe on the 996tt, more DD orientated.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on 6SpeedOnline!
It's not just about the brand, it's about the type of LSD. The quaiffe and OS giken are both gear type diffs which means that if both wheels loose traction (like if you go over a curb) there is no power applied to either wheel. The Guard Diff is a clutch type which can still supply power even if both wheels have lost traction. However with the clutches is less reliable.
I could be mistaken as it's been a long time since I looked into these but I'm pretty sure that is the case. Most of the time, on smooth tracks they'll be the same, but go to Sebring, or Road Atlanta where you're jumping curves and bumps and you'll feel the short comings of the Quaiffe and OS Giken pretty fast.
Someone correct me if I'm wrong.
Hello,
You are right that it's not about the brand and about the type, however, I'd just like to make a couple points of correction here. The OS Giken is not a gear driven (torque biasing differential). It is a true clutch type LSD. But you are correct that any TBD (either a Quaiffe or ours) will not put any power to the ground if you hop a wheel.
I also don't think it's wholly accurate to say that clutches are less reliable. Clutches have a service life. Depending on application the service life of those clutches is going to have a huge range. For a street car that sees the occasional track day, that service life will be tens of thousands of miles. Same thing for something like One Lap where they do a bunch of little short events. In those situations, I would expect ANY brand of LSD to last you 40-50,000 miles before it needs to be rebuilt.
But go run your car in a 6 hour, 12 hour or 24 hour event and that service life is substantially reduced, as it is on every other component on the car as well. It's pretty common for the top race teams to fully strip and rebuild any LSD after every race of those lengths. However, a PCA racer doing 1 hour enduros can often get a season or two out of an LSD between rebuilds. Like an engine, once you get into real racing it becomes more about hours of service than miles.
The last thing I'll just mention is that a TBD does not offer any lock up on deceleration. That's a feature that is only offered on a true clutch type LSD. This is why more road racers use clutch type LSD's. That lock up makes for faster lap times.
On the other side of the coin, that lack of lock up, and the fact that the TBD allows greater speed differentials between the two wheels from side to side is why many auto-crosser go with the TBD. It's that coupled with the fact the TBD doesn't dial in any understeer on tight turns that it's generally favoured.
Sorry for the hijack, but just saw a few points I wanted to clarify. With respect to the install of your Carbonetics LSD all you really should need is fresh bearings and the proper shims to adjust the ring gear. It should only take a few hours for the shop to get it in and get it right.
Matt Monson
Guard Transmission LLC
303-530-1094
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
HC, I thought that when it was called LSD, it automatically differentiated it from acting like an open diff. Both guard and quaife have LSD's and non LSD's. Very interesting.
Open diffs don't lock at all. That is what is on the 996 Turbo. All you do is spin one wheel uncontrollably. When I tried RWD at Barber I would leave clouds of smoke coming over the hill at turn 4 (about 100 mph blind overhill right hand turn).
The difference is that some diffs will lock both wheels if one loses traction. I thought the Quaife was, or maybe they used to be.
Peter, thanks for the clarification on the Giken dif. I got all the kinds mixed up so disregard my last post.
__________________ The GT-R is harder to drift than a 997 TT or 997 GT3, therefore if you are trying to drift, the GT-R will consequently get a faster lap. Normal apexing and driving not included.
Hello,
Are the GT LSD and the OS Giken direct competitors? IE --do they essentially do the same job? In a racing situation? In a high performance road car?
1. Quaife is good for AutoX/Street but track use if not its forte.
2. We ran the OSgiken in the One Lap GT2 and were very happy with it. The lockup under acceleration is very progressive and allows the car to rotate on exit, not push, and puts the power down well. Under braking from 150+ the car is rock steady and does not weave around under threshold braking like a worn out OEM LSD. In the One Lap @ Little Talledega Race Track morning session in the wet we were fastest beating all the GT-r's, Evo's, Subi, all wheel drive cars by being able to put the power down on exit. Install was seamless and done by an Independent Porsche shop.
3. We did a test for Grassroots Motorsports with my S2000 race car, OEM LSD (torque biasing) Kazz LSD, and OSgiken on the Ocala Kart Track. The OSgiken was fastest by a smidge. They other thing I found after we went to the OSgiken is our diff temps dropped. We used to come in from a race and the diff would be smoking hot and smelly. The OSgiken runs much cooler and we don't have to change fluids after every weekend.
4. I cannot compare it to the Guards as I have never driven a Guards equipped car.
I'd appreciate any feedback on your experience, since my purpose is also for mostly DD.
Sydney, Australia
Silver 01 996tt Tip
FVD ecu,DV's, BMC Filter,Exhaust,Brembo Floating Rotors
Sold: Austin Kimberly; Fiat 124cc; Fiat 124bc; Alfa Romeo GT2000; Fiat 128; Mitsubishi Cordia Turbo; Celica 90(2); Celica GT4(2)Celica GT4 Grp A; C36 AMG.
Extremely technical article(couldn't possibly read the whole thing)...amazing effort...but maybe of more relevance to engineers than end users who are more interested in how they perform.
Sydney, Australia
Silver 01 996tt Tip
Hi Matt, thanks for clarifying. In 996tt apllications, can you expand on the benefit for road use/road racing of locking up on deceleration.
Sydney, Australia
Silver 01 996tt Tip
A couple things you guys should know about me and our business, since I'm the new guy here. First off, I will never bash the competitor's product. It's just not how we do business. Secondly, if I don't know, I won't pretend to know. I'll just tell you that I don't or I'll go find the answer for you.
That said, my answer to the question is that they fancy themselves a direct competitor to us. However, I can't claim to have enough direct experience with their product to give you an honest answer. Reading their published literature and website I'm not even 100% sure what their locking percentages are. Furthermore, I haven't talked to enough people who have been running their differentials long enough or hard enough to give me an idea.
Everyone who is running their differentials seems to have good things to say about the performance of the unit. But that's also usually someone who is upgrading from an open differential. I suspect they would say the same thing about ours or a Quaiffe after running an open diff. Furthermore, I still haven't seen anyone speak up who has run it in a serious endurance event or through a hard season of racing.
My wholesale customers who are selling both our product and the Giken product are telling me that they are putting their "recreational" customers in the Giken. They are selling them to guys doing DE's in their street cars or running track days with their mates. When it's a purpose built racecar they are tending to stick with our product because it's a known entity with a proven track record. Also, when it's a high powered turbo car that could break something, they err on the side of safe and put in our GT2 chromoly differential because they know it won't crack. Factory GT3 diff. housings are cracking. They don't know if the Giken will hold up. So again, they play it safe.
Only time will tell where the Giken will fall out. 2 years ago the Kaaz was the latest greatest new thing to hit the market and a bunch of them got sold and put into cars. Some people like them. Some people broke them. I can't tell you where the Giken is going to end up in a year. People are going to have to buy them, run them, and tell us about them for us to know what's really up with them. Guys with powerful cars are going to need to buy them and see if they can break them. It's too early for me to give you an honest opinion of how good of a product it really is. My gutt tells me it's better than the Kaaz. Is it as good as ours? I don't know, yet. I'd be lying if I told you anything else.
Matt Monson
303-530-1094
Definitely have learned something about LSD's on this thread. I don't understand why an LSD would be designed to not provide power when a wheel lifts off, that is exactly why you get an LSD. So in other words the Quaife will not provide power in that situation that blows.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Concord Impresario Zenith mvmnt for sale and willing to trade for items listed in posting
Especially on these high powered cars that can hit unreal speeds on long straightaways, having the car stable under braking is essential. If you go read on some of the GT3 forums where guys are burning up the factory LSD plates in a couple of track sessions, you'll see their complaints about how the manners of the car change substantially when the LSD wears out and starts to act like an open diff. The tail gets loose and wags. For the higher speed cars it's really scary to have your arse end all over the place at 100mph under full braking.The LSD settles it down. It keeps the back end from wanting to walk.
Matt Monson
303-530-1094
Thanks, that makes sense.
In relation to " For the higher speed cars it's really scary to have your arse end all over the place at 100mph under full braking" ....or when it happens at over 200 mph flat out.....
Sydney, Australia
Silver 01 996tt Tip
Um, yeah. I was just thinking about the guys who come down from 160 or 180mph and are actually entering the turn close to 100mph. I'm lucky if I get my WRX up to 125mph on our local tracks, and dog knows my little 914 2.0l has rarely peaked past 105mph. You guys go scary fast in your cars...
Matt Monson
303-530-1094
***Only time will tell where the Giken will fall out. 2 years ago the Kaaz was the latest greatest new thing to hit the market and a bunch of them got sold and put into cars. Some people like them. Some people broke them. I can't tell you where the Giken is going to end up in a year. People are going to have to buy them, run them, and tell us about them for us to know what's really up with them. Guys with powerful cars are going to need to buy them and see if they can break them. It's too early for me to give you an honest opinion of how good of a product it really is. My gutt tells me it's better than the Kaaz. Is it as good as ours? I don't know, yet. I'd be lying if I told you anything else.
Matt Monson
303-530-1094***
Matt,
That is the reason I am posting my experience's with the OSgiken. I am probably 1 of the earliest users. True my GT2 is not a racecar but it turns sub 2:00 @ VIR and a 2:18.7 on Michelin PS2's @ Sebring. Weighing 3375#'s with driver. I admit that if I hadn't had experience in my T3 S2000 with the OSgiken it would have been much harder to install in the GT2 instead of 1 of your GT units. I guess somebody has to be the Test Dummy.
Peter
2002 996GT2 OSgiken/Rennsport Systems/Moton/with a few mods $$$$
2001 E46M3 with a lot of MODS$$$$ 3rd Overall 2009 OLOA SOLD
2009 OLOA 2nd Overall 2002 996 GT2
2008 OLOA 4th Overall 2005 996 GT3
2007 OLOA 1st SSGT1 SB E46 M3
2009 UTCC 7th overall. Fastest street car with AC/Cruise/full interior
Hello Peter,
I've seen your posts and will be watching you. And just for the record, I in no way betlittle your achievments at One Lap when I talk about it being a different usage within a range of applications. While it's a different kind of event, it's clearly still "real" racing in my book. In fact, we're involved with a car that will be out there next year. I'll look for you and try to say hi.
Also, if you decide to regear your car down the road let us know. While we're best known for out LSD's we do make gears as well. Steve at Rennsport Systems is a dealer and can help you run charts and analyze what might make an already fast car even faster.
Matt Monson
303-530-1094
