996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2.
Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 10-24-2009, 11:47 AM #16
Prche951's Avatar
Prche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond reputePrche951 has a reputation beyond repute
so you can go softer with the adjustable ones.
Does going softer in the front take out more understeer? what is the reason for going softer in front?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
- Concord Impresario Zenith mvmnt for sale and willing to trade for items listed in posting
Old 10-24-2009, 12:09 PM #17
FAST FWD's Avatar
FAST FWD is a splendid one to beholdFAST FWD is a splendid one to beholdFAST FWD is a splendid one to beholdFAST FWD is a splendid one to beholdFAST FWD is a splendid one to beholdFAST FWD is a splendid one to beholdFAST FWD is a splendid one to beholdFAST FWD is a splendid one to behold
Send a message via Skype™ to FAST FWD
Yes, that's the reason. I don't think that you can completely eliminate the push with just sway bars on a stock suspension. There isn't enough negative camber available, so the tires roll over too much and you lose too much contact surface on heavy cornering. You need about -2.5 degrees in front, -2.0 degrees in the rear. There isn't enough room in the fender strut opening to get that much camber, even if you were to grind the camber adjustment slots. (Yes, that is the voice of experience.)
The GT3 bars do it by moving the bottom out. I can back and forth from the track and street settings by adding/removing 14mm shims in the control arms. Toe also needs to be adjusted. About 10 full turns on the tie rods. I have the Longacre alignment kit (plates + measuring tapes) to fine tune the toe. It works very well for me.
Jon
_______________________________
2001 996 TT Orient Red
PSS9/DAS rollbar/GT3 rear, TRG front sway bars/Milltek exhaust
Upsolute flash/K&N filter/Front monoballs/Clear bra
Old 10-24-2009, 04:12 PM #18
TT Gasman's Avatar
TT Gasman is a splendid one to beholdTT Gasman is a splendid one to beholdTT Gasman is a splendid one to beholdTT Gasman is a splendid one to beholdTT Gasman is a splendid one to beholdTT Gasman is a splendid one to beholdTT Gasman is a splendid one to beholdTT Gasman is a splendid one to behold
Depends on the size of the new front bar, If it's a bigger diameter the softest setting may still be stiffer than stock. I strongly recommend you start with a rear GT2 bar only and go from there, you can always add the front bar later if you feel the need. FWIW my car with Bilsteins and a GT2 rear is neutral on R compounds.
Doug
Houston, Texas
'07 997 TT-> RUF 550 R Turbo
'08 Cayenne GTS
"Screw you, we're from Texas"...Ray Wylie Hubbard
Old 10-24-2009, 04:42 PM #19
Mikelly's Avatar
Mikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond repute
And actually, since we're splitting hairs, going Bigger doesn't always mean stiffer. If you're dealing with a "thicker wall" or "solid" bar, it may be as stiff, or stiffer than a larger diameter hollow bar.
Mike
UMW Tuned
K16-24 Turbos/Wastegates/5Bar FPR, Bailey DVs, VIVID Carbon Lid and SAMCO boost hoses!
Old 10-24-2009, 05:19 PM #20
garrickl is on a distinguished road
Anti-Roll Bars
I installed H&R's front and rear when I had the PSS10 setup installed and I'm very happy with the ride and handling. The car tracks much better and no noticeable roll or turn in--- in the corners.
2001 996tt, EVOM Stage 4 upgrades, Techart 19's, PSS10, Techart Exhaust
1978 930, 3.4 kit, EFI w\DTA box, G50, UMW k27, 993tt brakes, BBS w\C2 body kit.
Old 10-25-2009, 07:48 PM #21
Project911's Avatar
Project911 is on a distinguished road
RSS Adjustable Toe Steer Kit and RSS Adjustable Rear Link Kit really necessary after lowering your car??
02 Porsche Turbo
03 MBZ CL55 AMG
Old 10-25-2009, 10:44 PM #22
flash68's Avatar
flash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond reputeflash68 has a reputation beyond repute
Quote:
I was wondering the exact same thing.... ?
- EPL tuned
by Gearhead Garage
Reply
Tags
930, 996tt, bars, links, porsche, sway
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
