996 Turbo / GT2Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2. Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Anyone know the diameters on the stock sway bars? Does the H&R anti-roll sway bars(front bar diameter 25mm and rear bar diameter 24mm) make much of a difference?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on 6SpeedOnline!
The previous owner had that setup PSS9s and a rear sway and it was pretty good. Keep in mind if you put on the front one on later you will probably have to get the car aligned again.
01 996TT EPL K24/18G, Clutchmasters Stage 3 with LWF, SpeedTech Crossflow, PSS9s with GT3 Suspension tweaks, 997 Shifter, C20 HRE 18s
07 VW GTI DSG APR Stage 2 (DD)
Ex 1997 993TT Promotive (Should have not sold)
Ex 1998 C2S 993
Ex 1989 911
Sway bars have no effect on alignment.
_______________________________
2001 996 TT Orient Red
PSS9/DAS rollbar/GT3 rear, TRG front sway bars/Milltek exhaust
Upsolute flash/K&N filter/Front monoballs/Clear bra
Also I believe H/R offer a 26MM front bar as well... Last thing this car needs is MORE stifness in the front!
I'm running H/Rs and they're fine, but you'll want to run the front in full soft = outter most hole. Don't forget upgraded drop links. Stockers are JUNK!
Mike
Quote:
__________________ UMW Tuned K16-24 Turbos/Wastegates/5Bar FPR, Bailey DVs, VIVID Carbon Lid and SAMCO boost hoses!
Mike
if the front is so stiff, then do you really need an upgrade in the front?
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Concord Impresario Zenith mvmnt for sale and willing to trade for items listed in posting
No front bar needed, Ruf and others only use the rear bar, it works. I've yet to see somebody actually adjust the front bar on a turbo, last thing this car needs is more front stiffness.
Doug
Houston, Texas
'07 997 TT-> RUF 550 R Turbo To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
'08 Cayenne GTS
"Screw you, we're from Texas"...Ray Wylie Hubbard
thanks, seems like everyone is on the same page here.
An adjustable front bar allows you to make the front softer than stock, so it is useful. Being able to adjust both ends allows you to fine tune the balance. I started with just a rear bar, and eventually added the front one for this purpose.
You really need to have more negative camber on these cars to make them handle correctly. For that you need the GT3 lower control arms, front and rear. (Or, GT3 arms up front and adjustable upper dog-bones on top in the rear, which is what I have.) With those, it does help to be able to adjust both ends.
My car is now very neutral, and I got 9 track days from a set of Michelin PSC's. They have another couple of days in them, but I ran out of time for the season. When I first got the car, 3 days and I was down to the cords on the shoulders front and rear. The car handles a lot better too.
Jon
