996 Turbo / GT2Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2. Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Does anyone have the problem filling up their gas tank. When I go to the gas station I like to "fill her up". I mean I like to get a full tank of gas. When I try to fill up my 996 tt the auto shut off on the pump makes it so I have to keep on resqueezing the handle. Any suggestions???
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on 6SpeedOnline!
Yup the best you can get is 3/4 if tank unless you hold the nozzle at an extreme angle. But be careful, you and also flood the evamp canister.
03 996TTX50 Coupe Black
05 AMG C55 Silver
06 X3 Silver
In loving memory of my bank account
95 993 RS look Couple Black
85 911 Coupe Guards Red
83 911 Cab Artic White
80 911 Coupe Met Black
78 911 Coupe Cashmere
99 AMG C43 Black
97 M3 4dr Silver
95 325i Black
85 318i Black
(notice no new cars between 85-95 that's was being married does to you)
I have the same problem on my 996TT, talked to other turbo guys and all have the same problem. There's a way to reset it, but I think you need to empty out the fuel. Any tech support here...?
1. Leave the car running
2. Don't pump at full speed
3. For some reason older gas stations without the newest evaporative collection systems (the flexible hose that goes over the nozzle) seem to work best
It's a very common problem. Sucks to fill the already tiny gas tank and drive away only 3/4 full.
My latest dyno chart 1.2 BAR: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
2002 X50. Water cooled Tial GT2860RS, EVO Clubsport Intercoolers, Speedtech Y-Pipe (red), Boost Hoses, 60 lb Injectors, LWFW, RS Clutch, Remus Exhaust, DVs, GIAC FLASH To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , 997 TT Brakes, FVD PSS9s, H&R Rear Bar, 19" Champion RG19 Monolites (15mm spacers front and rear), rollled fenders, ROTtec CF Lip and rear window spoiler, Strosek Wing.
I usually turn my key to ignition 2 and try filling to the full line before I stop pumping.
Someone told me to hold the nozzle upside down, but it didn't work for me. With my car, I need to hold the nozzle in around the 8:00 position... fill up all the way without a click.
2004 Carmon Red Cab + Tip (7000rpm)
EVOMs GT660
Had this problem and solved it by pulling the nozzle out and then putting it back in. I need to do this a few times if I want a full tank, but it works. Not sure why
__________________ Turbo Cab 2004 Turbo Cab X-50 San Diego, CA
Wow...I can't believe this many of you have to go through hoops to fill the tank. Anyway, things in general regarding fuel filling (that I have heard of)
1. Fuse, E6 (usually fuel will squirt back at you)
2. Pinched vent tubing (TSB 5/99, 2015)
3. Incorrect fuel level display (TSB 01/04, 2066)
4. Calibration issue
5. Various "legends" about nozzle differences, angle of entry and depth of entry (OK I know what you guys are thinking...gutter minds)...I have heard 9:00 position works better...LOL
6. Fuel pump, ruptured fuel lines...all resulting in car won't start
7. Fuel level sender unit (either failed or the floater arm is stuck behind hoses)
8. Fuel filter (only pre '02 as post 02 the filter is integrated)
__________________ Statman
1. Put the nozzle in and engage the hands-free mechanism at the maximum.
2. When it clicks off, grip the handle and lift it up and toward the car like you were pouring a bucket.
3. While holding in that position, squeeze the handle all the way and stay in that position until it clicks off again.
4. You now have a full tank and you should see a tiny pool of fuel sitting on the metal flapper.
I had this problem before. Try pulling the nozzle out a little, just enough that it is still the tank but not all the way out. Just enough to compensate for the automatic shutoff on the handle
