Solid Engine Mounts: What do people know and think?
996 Turbo / GT2Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2. Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
I think the way it breaks down in stiffness is this from what I learned when I was looking:
stock - softest
X73
RS
Wevo - black
Wevo - blue
solid
I got wevo black and I cannot feel any difference, but then again, I have a very loud exhaust and a lwfw.
The Wevo Black is slightly softer than the blue. From my understanding about 10% difference is all. The wevo also has incredible craftsmanship compared to the others. The amount of eurethane inside the wevo's is so minimal it is hard to believe that it does anything. it is nearly a solid.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on 6SpeedOnline!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Concord Impresario Zenith mvmnt for sale and willing to trade for items listed in posting
Going back to JCB's original question... the new mounts are adaptive. Accelerometers in the vehicle sense the turn, and then stiffen the mounts by applying a field. The write-up I saw didn't say, but this is usually done using magnetic actuators. That makes the mounts stiff while cornering, and soft while driving. Sort of like sway bars for your engine.
Because they are actuated based on feedback from accelerometers in the vehicle, they aren't going to work in our cars.
Jon
_______________________________
2001 996 TT Orient Red
PSS9/DAS rollbar/GT3 rear, TRG front sway bars/Milltek exhaust
Upsolute flash/K&N filter/Front monoballs/Clear bra
stock - softest
X73
RS
Wevo - black
Wevo - blue
solid
can someone post approx prices for each of these mounts, for future reference
I am not sure as to all the prices, but I think they are all in the 400 to 500 range. Cost is very close, so price is not part of the decision process.
First, Sorry but I've got sick relatives, my companies annual party tonight, and a trip next week... Been very busy...
Jeff, I would NEVER use metal mounts on a street car. You're going to transfer all the engine harmonics straight into the cabin.
Second, Jim, YES WEVO came out with a different mount for the 997TT, which works with the 996TT. I don't know why anyone would spend the extra money, though. Most of the 996 and early 997 GT3 guys use the WEVOs that I ordered and have used, and they're the ones who I got the tip from!
You do need to order a longer bolt/nut setup from Mcmaster-Carr:
91280A745Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M12 Size, 130mm Length, 1.75mm Pitch, Partial ThrdIn stock at $8.52 per Pack
91005A038Metric Black-Oxide Steel Flange Hex Nut M12 Screw Sz, 1.75mm Pitch, 19mm W, 17mm H O'allIn stock at $3.48 Each
They come in volumes of 5 each. So a couple of you guys could go in together if you are close to each other... before the propeler heads come out of the woodwork and ask about the bolt strength, 8.8 is what was stamped on what was shipped from WEVO.
PRICE as were quoted to me a while back:
X73 - $450
WEVO Black -$300 (Plus hardware replacement)
WEVO Blue - $300 (Plus hardware replacement)
WEVO 997TT - $400
MotorSport RS - $500
Took me less than an hour with the lift and a jack to support the motor. I did one side, then the other. You could do this with the car on the ground and the jack to support the motor (use a hockey puck or wood block between jack and motor).
Anyone in my area is more than welcome to my assistance (and my lift) in upgrading to these. Think I even have an additional nut/bolt setup, so that maves it even easier. Gunther, Landjet, BLKMGK, that means you...and others who may be lurking.
Mike
__________________ UMW Tuned K16-24 Turbos/Wastegates/5Bar FPR, Bailey DVs, VIVID Carbon Lid and SAMCO boost hoses!
ALL of the mounts listed are substantial over stock... The stock mounts on a modded car are JUNK!!! Those and the droplinks are two of the biggest weak links on this car!
Mike
Mike
my stockers, look brand new. The car was such a virgin. Anyway, I remember there being a discussion about converting the stock mounts into semi solids. That is definitely another option that would be considerably cheaper and get similar results.
My stock mounts also looked (and still do) brand new with only 24K miles on them. No evidence of tear or ripping. But Dennis, they have a lot of flex to them.
Mike
Mike
Mike, you are right, but there was a DIY on how to convert the factory mounts to semi solids by filling them with a resin. It was a detailed article and I just spend an hour of my life looking for it to no avail. oh well. I know I read it and I usually save links like that. But didn't this time I guess.
2001 996TT Seal Grey mostly stock To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
I just replaced my mounts w/ the brand new (and more expensive) Wevo 997 SS mounts. I haven't driven the car yet but will sometime this week and will then report back.
2001 996TT Artic Silver EVOMSit Flash EVO headers AWE Exhaust GT2 Wheels w/ MPS 235/40 ZR18 and 315/30 ZR18 7mm Rear Wheel Spacers
SS Brake Lines PSS9's Pagid Blue Brake Pads Smoked Rear Center Light 3M Clear Bra Rear Center Console Artic Silver Schnell Short Shifter Clear Side Markers EVO Hose Kit EVO Intake V1 Hardwired EVO Diverter Valves Optima Red Top Battery Ultimate Alluminum Pedals Factory 2004 Engine Installed 6/2005 GT2 Exhaust Tips Sachs Stage 2 LWFW
Dtmarsh what how did the install go and where did u locate the mounts? just engine or transmission mount also?
