Drivetrain loss, explained
Rating: Thread Rating: 2 votes, 5.00 average.
Old 07-27-2010, 07:53 PM
Divexxtreme's Avatar
Great article.
Drivetrain loss is a common topic of conversation in the tuner world because any time you strap your car to a chassis dyno, the output being measured is at the wheel, not at the crank like the published SAE net horsepower figures used by the auto industry. Strap your 298-bhp RevUp G35 Coupe to the dyno and you may be disappointed to see little more than 220-230 horses measured at the rear wheels. Where did that 60-plus horsepower go missing? It was used up in a variety of ways before it could reach the drive wheels, the primary source being what's broadly described as drivetrain loss.
What's interesting about this example is that when you do the math you'll see that the percent loss is much higher than the 15 percent "rule" you'll find in any number of online threads on the subject. For whatever reason, drivetrain loss seems to be one of the most poorly understood subjects discussed on online car forums, so despite my love of the Internet and the limitless pornography it makes available to me, when it comes to a fairly technical subject like this it's hard to find good information.
A few years ago, I needed to educate myself on drivetrain losses while heading a rulebook committee for a local racing series that wanted to use dyno tests to measure engine output and then convert the results to net horsepower. After fruitlessly Googling and sifting through endless car forum threads polluted with half-truths and misinformation, I turned to the same source that developed the current manufacturer horsepower standard, the Society of Automobile Engineers (SAE). On its website you can access brief summaries of technical papers published by some of the world's leading automotive engineers and download the complete documents for a relatively small fee (usually less than $10 per article). As luck would have it, in 2002 the SAE held a symposium on transmission and driveline systems, and the papers that came out of it covered drivetrain loss in great detail.
One of the first things I learned from reading these papers was to completely disregard the 15 percent drivetrain loss "rule" (or any other percent value) that so often comes up during online discussions of whp versus net horsepower. The fact of the matter is every vehicle experiences different levels of drivetrain loss as determined by the design of its transmission and driveline components. Simply put, the amount of horsepower lost to the forces of inertia, drag, windage, pumping and friction are different for every engine, transmission and driveline design.
So the total power lost between combustion and forward motion is specific to each vehicle and therefore no single rule, percentage or fixed number, could possibly apply to all vehicles. Even on the most superficial level, this is easy enough to understand because an all-wheel-drive Subaru obviously has a lot more driveline components to spin (front, middle and rear differentials along with front and rear driveshafts and two prop shafts) and a beefier transmission to hold all that turbocharged torque, so it's naturally going to suffer from greater drivetrain losses than a Honda Fit with its much smaller and less robust transmission, smaller and lighter driveshafts (and no prop shaft) and single differential.
Breaking down the different types of losses that occur within a vehicle's drivetrain, steady-state losses occur while the vehicle is cruising at a steady or constant speed, where average angular acceleration is zero because no additional torque is being called upon to accelerate the drivetrain's rotational mass. Within the drivetrain, steady-state power losses occur from the following components: the transmission torque converter (in the case of automatic transmissions), the transmission oil pump, clutch pack drag, one-way clutch drag, seal and bearing drag, gear windage and friction, and final drive losses.
Dynamic drivetrain losses, on the other hand, include the rotational inertial losses from angular acceleration occurring within the drivetrain while accelerating. In fact, during acceleration there are losses from the rotational inertia of spinning transmission and differential internals as well as driveline components like driveshafts and prop shafts, but also from the increased load and friction being generated between the gears within the transmission and differential(s). And as you already know, with increased friction comes increased heat (more on that later).
It's important to understand the difference between steady-state and dynamic losses because SAE net horsepower, as reported by the auto industry, is measured in a steady-state condition. What this means is that the horsepower rating for your vehicle doesn't take into account dynamic losses that occur during acceleration. However, when you strap your car to a chassis dyno to measure its engine's output, the test is conducted at wide-open throttle and power is measured by the speed at which the dyno's rollers are accelerated. This means that drivetrain losses from rotational inertia and increasing friction, drag and windage are at work and will reduce the peak horsepower reading at the wheels.
Within the drivetrain itself, the primary loss sources are the differential and final drive, with further losses stemming from within the transmission, and in the case of AWD vehicles, from the transfer case. Within the transmission, as much as 30 to 40 percent of power loss can be attributed to the pump, with the clutch contributing another 20 to 25 percent. The rest of the loss within the transmission comes from seal drag, gear meshing, bearings, bushings and windage (drag on the gears caused by the gear oil). However, when dyno testing in the direct drive (1:1) gear, power is delivered directly through the mainshaft of the transmission, so the only loss sources are windage, friction and drag, resulting in total at-the-wheel losses as low as 1.5 to 2 percent, according to the published data.
Differential losses tend to be considerably larger, especially in the case of RWD and AWD vehicles where the torque path is turned 90 degrees as it enters the rear diff and exits it toward the rear wheels. In the case of hypoid-type gearsets (where the gear tooth profile is both curved and oblique) that are commonly used in RWD differentials, losses in the 6 to 10 percent range are the norm, while loss from the driveshaft(s) and prop shaft(s) tend to account for about 0.5 to 1 percent of total loss, depending on how well they're balanced and how many the vehicle is equipped with. In the case of FWD vehicles, the torque path is more direct to the front wheels and the use of efficient helical final drive gears means that drivetrain losses can be as much as 50 percent lower than on RWD and AWD vehicles.
In any drivetrain component with meshing gearsets, heat generated by contact friction between the gears is a significant contributor to drivetrain loss. This is true during steady-state driving, but is far more of an issue when the throttle is mashed to the floor and the resulting thrust force and angular acceleration builds up in these drivetrain components. The heat generated by this dynamic friction is absorbed by the transmission and differential fluid as well as radiated to the atmosphere through the transmission and differential housing(s), and in some cases, via a heat exchanger or oil cooler. This absorbed and radiated heat is literally the conversion of engine torque into thermal energy because you can't technically "lose" power, but can only convert it into other things (some of our favorites being forward motion and tire smoke).
It's also worth noting that the more powerful you make your engine, the greater the thrust force and angular acceleration it's able to exert on the drivetrain, generating even more friction and heat in the process. But because both steady-state and dynamic friction vary depending on engine speed, engine load and the efficiency of the engine and drivetrain's design (how well they limit friction and the associated thermal conversion of torque to heat), there's no way to apply a universal percent loss to it. Nor is it possible to apply a fixed drivetrain loss figure to your car (say 60 whp from my RevUp G35 example), because as you modify the engine and increase its output its ability to generate thrust force and angular acceleration also increases (though not in a linear fashion).
In the end, there's no easy way to estimate the drivetrain loss your vehicle experiences on the road or even on the dyno. Coast-down tests are sometimes used on a dyno to attempt to measure frictional losses, but because this test is not dynamic (meaning they're not done while accelerating, but rather while coasting to a stop with the direct drive gear engaged but the clutch depressed so that the engine and transmission aren't linked) it really only captures steady-state drivetrain losses as well as rolling resistance. So rather than attempting to convert your vehicle's dyno-measured wheel horsepower to a SAE net horsepower figure using a percentage or a fixed horsepower value, you're far better off accepting the fact that these two types of horsepower measurements aren't easily correlated and forego any attempt at doing so.
http://www.modified.com/tech/modp-10...oss/index.html
Old 07-27-2010, 10:04 PM
Turbo Fanatic's Avatar
great article! thanks!
What i read in here is that a Dyno is the most effective way to determine performance. Realistically the torque curve tells the whole story.
going in for another custom tune Thursday! This time taking some 104.. whoot
Old 07-27-2010, 11:08 PM
Prche951's Avatar
so in other words I have 15 awhp
Old 07-28-2010, 12:20 AM
kwei's Avatar
kwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud of
lol...nice!!!: )
Old 07-28-2010, 12:56 AM
cjv's Avatar
cjv
cjv is offline
Moderator
It is a lot more confusing than what the article portrays.
People came around to the 15% or whatever loss by taking the manufacture's published bhp (engine dyno) numbers and then running then on a chassis dyno. In many cases people using the chassis dyno didn't know what hp reading the chassis dyno was set to read. Standard SAE being the most restrictive or others to make the numbers look better. Great selling tool for a particular product or part.
Now to even a bigger issue. People try to use the manufacturer's bhp numbers and convert the chassis number to the known bhp number. Even if was theory was to be a correct one, (which the above article provides some good information why it is not) there is one variable that varies widely. That variable is the actual bhp of any particular motor after break in or seating of the rings. I have seen variances as much as 24-25 hp in different stock 996tt motors.
The point being the factory has done a scientific test with idea conditions to determine the actual hp their test engine can produce after idea break in conditions. If they had taken that motor after engine dyno and installed in the car and run a chassis dyno test they could tell you the loss for that particular car set up with the chassis as it was.
You move to the production mode with an uncontrolled break in procedure along with varying drivetrain components and you have nothing more than an educated guess.
This is why a chassis dyno is best used prior to modifications to determine the actual gain provided by a particular modification/s. The problem can compound again when multiple modifications are performed and then attempting to attribute a certain gain to one of those modifications.
Old 07-28-2010, 08:59 AM
Joe Weinstein's Avatar
And in the real world, unless you're actively considering changes to the parts of
the car that contribute to drivetrain loss, such as if you're comparing two different
types of transmission, or considering converting from AWD to 2WD, any bantering
about the 'flywheel horsepower' is a pointless mind game. What you have is what
what you get at the wheels. 'Flywheel/engine horsepower' is like describing your
wife, not counting the in-laws and jewelry budget. Stay real brother.
Old 07-28-2010, 09:43 AM
ttboost's Avatar
So that's why my tuner said I could get 2500hp with my 18g's, but I would never see it at the wheels... I guess I have 76% DL loss!!!
Old 07-28-2010, 11:08 AM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
I'd hurry up if I were you and get on that drive drain issue and you will be under 4s in no time.
Old 07-28-2010, 11:16 AM
Yep. Sure we can guess using 12.5% or 17.5% (RWD and AWD, respectively), but the accuracy is certainly in question (as per the article).
I think the best thing to do along with chassis dynos are to get trap speeds, 60-130 times and other comparable acceleration data. That's pretty much it.
Old 07-28-2010, 11:50 AM
mtesh73's Avatar
mtesh73 will become famous soon enough
lots of good info>>
great read. like stated in earlier posts, i guess i should be happy with 2 digit horsepower #s, someday i will break 100 .
Old 07-28-2010, 01:34 PM
But we live in a numbers world.. and everyone jumps when someone takes a turbo with a bunch of other parts, turns up the boost, dynos it to their liking and publishes the numbers... we all go WOW how did they do that...
Take it to the track or run a P box and get a 1/4 trap in mph... that will not lie...
Not bashing anyone... I am actually speaking about myself when I was uneducated and ignorant and bought into the published HP game... heck I remember back when I supposedly had 575 hp... I wanted 650hp so much... it was only $12K more... yet later to find out that both kits trapped the same at the track... but it was too late... I lost $12K...
if you choose, choose wisely...
great article,
best
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 07-28-2010, 02:41 PM
ttboost's Avatar
+1. As is said and has been said many times before, the dyno numbers only means something if you have a before number and an after number on the same dyno. It's called progress. I really have no idea how much power my car makes now. BUT, I know it traps 133-134 and on a good crisp cool day it runs 60-130 in the 5's (barely). Since we have been tuning my car (from stock) I have picked up 257whp. Who knows what the before number and after number really is!!!
Old 07-28-2010, 02:51 PM
th3Stig's Avatar
th3Stig is a glorious beacon of lightth3Stig is a glorious beacon of lightth3Stig is a glorious beacon of lightth3Stig is a glorious beacon of lightth3Stig is a glorious beacon of light
The only way to truly compare results is a back to back comparison on the same day, but even then variables will come into play with humidity,temps and everything else considered (clips, fluids, tolerances...)
That said: it's about time someone posted up an ASE article summation on this subject instead of a circle-type argument thread I have seen so many times before.
Old 07-28-2010, 04:47 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Great article Scott,thank you much
Old 07-28-2010, 04:57 PM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
Scott, I can't give you rep points now because I "have to spread" some rep first.
But anyway this is an excellent article. Thanks for posting.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Drivetrain loss, explained
