terrible rattle on start up
wow most of the chatter went away. JP, I think I read that you did the non return check valve replacement? obviously it didn't get rid of the noise. Was it a difficult procedure to do? I might replace it and see if it helps in addition to trying some different oil with more ZDDP.
I've used Castrol Syntec 5W40 and the growling came back after 800 miles. I've decided to replace it with Mobil TDT, the growling was there the next day but less sensitive and after over 500 miles almost completely gone. Why??? Sorry I don't have a clue, May be ZDDP... But I am not celebrating yet , need may be another 1500 miles before calling it the best solution for my engine.....
Mine clicks when I first start it and then it goes away once it's warmed up and you only hear the IMS rattle. From past experience w/ my BMW 335, which made the same noise, I believe it's a valve lifter. I will take a video tomorrow. Rainey, I only wish my 996tt sounded like yours lol.
I wouldn't bother replacing the check valve since the TSB for the issue states that the low pressure warning light would come on at start if it needs to be replaced. If your light doesn't come on don't bother replacing the check valve. This topic has been discussed many time on 6SO, rennlist, renntech, and all come to the same conclusion, if there is no light its normal. I guess if you want to avoid the noise just drive the car more and enjoy it.
I have one of the early TT engines (2000).....61k miles, but if it sits no more than a week, it doesn't rattle at all at start up. It sounds pretty "tight" actually...
If I start it after more than 7-10 days, it rattles a tiny bit for 1-2 seconds.
I'm running Mobil 5w50.
This is my car after cold startup for not driving for a week. Scared the crap out of me when I first got it, but after it warms up, don't hear anything but the IMS rattle. The clicking noise at the beginning does still worry me though. Still have a noise though between 3-4k that sounds like IMS chirp though, but 2-3k nothing but exhaust.
http://www.youtube.com/watch?v=NkcpDE0694I
What you're hearing is one of your hydraulic valve lifters sticking. Once the engine warms up a little the oil flows better as it thins out and pressurizes the lifter and the clicking sound slowly goes away. If you jack up the rear of the car and lie down under the engine, you should be able to localize the cylinder that has the sticking lifter. There is nothing you can really do about it, maybe going to a thinner oil like the OEM M1 0w40 unless you are already running it....or drive the car more often.
in most cases if a 996tt lifter makes clicking noises, it do not be possible to switch for the high cam profile....so you fuel consumption goes low and your power goes down....(you dont feel it...because it is only one intake valve of two per cylinder and it lifts 3mm instead of 10mm)
at this point check exactly your oilfilter....
if you didnt find anything in your oilfilter you are on the sunny side.......i have found some particles in my filter...today my engine is out maybe on monday i know more...
Yeah it's normal from what I've read. Mine does it too but only if the car sits for 2 or more days. It usually only last a couple seconds though, not 5 minutes. Supposedly its the hydraulic lifters running dry because the oil drains down from them when the car sits unused. It takes a couple seconds for the oil to get back in them.
mine sound exactly the same in video above...then i found particles in olfilter...i changed my oil and filter and after that i found only one ore two particles again...i changed my filter again and after that i found nothing....
today my engine is out and i will clear this situation....next week i know more.
