Boost Leaks- how to find them... pics inside
Old 10-17-2011, 03:15 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Originally Posted by heavychevy
Someone please move their Porsche tuning services to Atlanta please. Thanks.
Yes please go to Atlanta........DON'T come tuning your Porsche to El Salvador because,at the Dealer,they got confused with a VW
IT'S NOT A JOKE
  #47
Old 10-17-2011, 03:25 PM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
Originally Posted by MARKSKI@911tuning
I will... I found more leaks now that I fixed the O ring to the TB leaking...
On top of the engine valves never sealing all the way, it seems like most turbos will leak from the cold side if you are putting compress air into the inlets. Therefore, I do not see how you will ever get the car to hold decent pressure, especially at high PSI
  #48
Old 10-17-2011, 03:26 PM
bad107's Avatar
After following Markski's advice of boost testing, I found a small leak at the MAF and diverter valve and a large leak at my TB. Thanks Markski!
  #49
Old 10-17-2011, 03:49 PM
No problem...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
  #50
Old 10-17-2011, 08:36 PM
Hogapalooza's Avatar
Hogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond repute
I'll need to do this before my tune. Thanks for the great thread.
  #51
Old 10-18-2011, 07:17 AM
Slik560's Avatar
Slik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond repute
I don't even own a TT yet (still looking) but I subscribed to this for future reference. Excellent information.
  #52
Old 03-21-2012, 09:45 AM
vshugo996's Avatar
vshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to behold
Hi,
I tryed to do a plenum leak test but I think that any thing is wrong.
I lowered the engine, disconnet the Y-pipe and install the leak tool to the plenum. Next, put air but could not see/feel pressure inside the hoses. I listen the air run inside the plenum and hoses. I spray all the hoses and plenum with water+soap and couldn´t detect any leak.
If there are no leaks I think the air goes to inside the motor by engine intake, correct?
What are the correct procedures and fases to do a plenum leak test?
Regards,
VS
  #53
Old 03-21-2012, 12:50 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
Originally Posted by vshugo996
Hi,
Regards,
VS
Did you block off (seal) this hose?
Old 03-21-2012, 12:54 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
Agreed.
I would probably disconnect the hose connected to the check valve portion of the venturi tube (to the left of the arrow in the pic above), as this check valve can leak, alternatively you can remove the clip and remove it further down the line and check it while pressure testing, either way. Mine was letting air pass, although it was not excessive @ 10-15 psi .. I went ahead and replaced it, the new one was air tight at the same PSI.
  #55
Old 03-21-2012, 01:10 PM
USAF_TRobertson's Avatar
USAF_TRobertson is on a distinguished road
Can we make this a sticky?
  #56
Old 03-21-2012, 02:10 PM
Speedtrapped's Avatar
Speedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant future
Ok...still a noob to this platform...I bought Alan's 996TT, protosprt stuff, makes 640chp...I want to pressure test, I remember quite well from my RS6 days, boost leaks suck, and smokers dont test for real PSI....so, I can jack the back, pull the turbo inlet hoses, cap...remove Y pipe(TTboost kind enough to share his tester) and pressurize? sounds simple...soapy spray in windex. sounds about right?
  #57
Old 03-21-2012, 02:12 PM
ttboost's Avatar
Sending you boost leak tester and 2 blocks offs , 1 for each turbo. Already packed, so no pics...
  #58
Old 03-21-2012, 02:23 PM
Mike....I owe ya beer...cheers!
  #59
Old 03-21-2012, 04:45 PM
vshugo996's Avatar
Yes, I block this hose and the F hose too. However I can get pressure!!!!
  #60
Old 03-21-2012, 08:42 PM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
Wow some of you still have leaks after all this reading? This is the first test anyone should do even before a tune!
This is free hp!
I have to agree this should be a Sticky
Quick Reply: Boost Leaks- how to find them... pics inside
