Boost Leaks- how to find them... pics inside
#61
Hi,
I tryed to do a plenum leak test but I think that any thing is wrong.
I lowered the engine, disconnet the Y-pipe and install the leak tool to the plenum. Next, put air but could not see/feel pressure inside the hoses. I listen the air run inside the plenum and hoses. I spray all the hoses and plenum with water+soap and couldn´t detect any leak.
If there are no leaks I think the air goes to inside the motor by engine intake, correct?
What are the correct procedures and fases to do a plenum leak test?
Regards,
VS
Regards,
VS
Thanks,
VS
#62
Check for small vacuum leaks...I had a hose pop off and pulled my hair trying to find it. Boost leak check wouldn't find it, but a smoke test did...
https://www.6speedonline.com/forums/...en-solved.html
#63
However, now is important for me undertand if there are no leaks the air goes to inside the motor and is normal do not get pressure?
#67
Who do you use with this level of confidence to do a throughly boost leak test like this in Toronto?
Bobby Ali
ba
#69
Chad, What would you charge to test mine?
#70
Bobby Ali
ba
#71
Have the guys at Autowerks do it no?
#72
Hope I'm not reviving an old thread. I'm trying to leak test. I tried through the Intake pipe and also through the turbo's.
My question is, I blocked off one turbo, and then pressurized through the other. The system would not hold air at ALL. Is there something else I need to block off up in the top of the motor if I'm pressurizing at the turbo's?
I know I've got to be doing something wrong?
If I still have a blow through MAF should I skip pressurizing at the turbo's and just pressurize from the intake tube? If I do that is there anything I should be disconnecting or blocking off to make sure I don't mess something up?
#73
#74
When I pressurized at the Turbo's I had air coming out a line that 'T' into the connecting pipe on the drivers side between Turbo and Inlet pipe. Just flowed through like crazy.
#75
Ah ok. That should not happen.
