Key hard to remove from ignition lock
+1 Get it repaired ASAP. The next step in the failure process is a lot less convenient to deal with.
Search a bit, and you will find that it's a VW part number that you can buy for $7 at NAPA, as opposed to exact same part (number and all) from Porsche for $40.
Jon
Jon
I had my ignition switch go bad.
Started as key being hard to pull out and turn, then after a while I could hardly get the key out.
Had to replace the ignition switch, did it at the dealer it wasn't cheap for me, I'd have to check how much it was.
If somebody could give me the part number it would be appreciated. I thought it would be a dealer job as it would require coding? Does changing the ignition switch not mean that you need to change your keys?
You need to take out the a/c vent on the far left of the dash. That gives you access. The hardest part will be loosening the two screws that hold it in - they are given a dab of red wax to make sure they don't back out. There's not much room to work. I have a mini socket set that has a ratchet wheel that I used to hold a small screwdriver head. You get to one of those screws through the hole for the a/c vent. The other one you have to get from below. If the door sill is digging into your back on the right side, the seat is digging into your back on the left side, and the clutch pedal is stuck in your ear, that's the perfect position.
Jon
Here is a photoless DIY in changing the complete mechanisim 996 347 017 07 which I will be doing
http://www.renntech.org/forums/tutor...or-996boxster/
