Radiator replacement?
Hi All,
The group buy from GMG for the CSF radiators is great timing for me. I want to post a few photos of what I found last weekend when I removed the front bumper to replace a horn. The left radiator isn't that bad with a little bit of crusting at the top, but dry for the most part. The right was a bit worse with active wetness. I didn't see any leakage around the center radiator, but I am wondering if you think I should replace all three. The local dealership said not to replace it if it isn't leaking. I want to get in on the group buy but I have to make a decision on spending the extra $500 for the center.
Let me know what you think. My car is an '04 X50 Cab that we just bought a couple months ago. The radiators were missed on the PPI along with a wonky throttle body. More on that later...
Thanks,
Franny
Thanks,
Franny
Thanks Guys,
I ordered a complete set this morning. Probably a couple weeks lead time.
What else will I need assuming the hoses are good (they seem fine... no leaks)? Three gallons of coolant... Anything else?
Any weird tricks getting them out and back in? Will the AC heat exchangers move out of the way easily enough?
Thanks again,
Franny
Thanks again,
Franny
Goodstuff!
If the hoses are original I'd be replacing those as well, the hoses are actually very cheap comparatively.
Really no tricks to the job, just be careful with the A/C condensers and have at 'er!
Cheers,
Rob
Cheers,
Rob
It helped a lot when bleeding to jack the rear of vehicle to allow coolant to fill the system.
Odd man out here and a contrarian by nature.
Service manual will help you out, but actually it's pretty straight forward and fairly simple. I do this stuff for a living, BTW and hate working on my own cars, hate it worse for others to work on them.
A couple of years ago I was talking to my friend, a senior tech at Porsche about radiator tank seepage. He mentioned well over $1K and less than $2K if I brought it by the shop, then turned and whispered, "Alumaseal".
$6.50 later, 100% seal, no coolant loss in 2 years, 105 degrees last summer, no fear of summer long distance travel, 167 mph pull, all good :-)
Got sent early duh but yes it would be cheaper to repair or replace one etc but the new ones should out last the car. I personally tend to over do it which usually only helps future owners not my checkbook lol.
