Pinning cooling outlets, misc. hoses part numbers.
As I stated earlier, I am half way through my project, but in case others want to do it I am posting part numbers for 5 hard / impossible to replace hoses without pulling the motor.
996.106.512.72
996.106.529.71
996.106.477.73
996.106.233.72
996.106.328.72
This will save you some ordering time.
Some pics for you critical viewing pleasure.
996.106.512.72
996.106.529.71
996.106.477.73
996.106.233.72
996.106.328.72
Hoses are like new, perfectly firm, yet elastic. I treated all with silicone and replaced some vacuum lines.
Here is my list of replacements:
water pump
thermostat
fuel filter
drive belt
voltage regulator
new OEM clutch
flywheel bolts
rear main seal
clutch slave cylinder assembly
spark plugs
orings and gaskets
I found everything I checked in impressively good shape, as if she was never abused.
Please advise where else to look.
its not a matter of abuse but rather age. 10 yr old rubber hoses and vacuum lines may deteriorate on the inside but look fine on the outside
You are right, will order the rest of them.
There is a check valve at the top that comes off the plenum (driver's side I think). Also a 3 way valve under the plenum. How does the coolant tank look? If it hasn't been replaced may as well get a new one as it'll probably crack soon (also get a new radiator cap).
Might want to do the oil pressure sender too
Make sure the cap is also new. When I got my car it was an outdated part number, I replaced it with a new one from Pelican and 3 months later the dealer did a pressure test for me and told me my new cap was also bad :/
04-28-2022 12:38 AM
awdbiturbo1
02-18-2016 10:24 AM
ECS Tuning - VW
08-19-2015 08:58 AM
