How much for a pull out motor?
Some of you might remember that I blew up a little more than a year ago. I have been busy with some other projects and career stuff so I let the car sit for a while. I am now tearing it down and am considering my options. What did you pay for a pull out? Any suggestions on where to look would be helpful also. Thanks!
basic build would be rods, headbolts and full gasket bearing kit, 997 lifters. approx 11000$ with labor. of course if pistons, crank or head parts are needed the cost will go up. but you will have a stronger better built engine than any pullout and you will know its done right. just my .02
I have no oil pressure and oil on the ground, so my guess is that the bottom is toast with a hole in the block. The dead piston did not hit the valves however, so I think my top is ok. It seized as I shifted and the computer would not let it rev up again so I shut it off as it was idling. So I believe the heads are good. What can I sell them for?
faiz
09-02-2015 08:43 PM
