Help now with a 911 Turbo purchase Airbag light on
I just flew 700 miles to buy a 2001 911 Turbo. My concern is the Airbag light is on. He has a note from a Porsche dealer that it could be the passenger side seat belt not grounding and a harness? What could this be, and how expensive to fix? Is this a common problem. BTW the Brake light for the low brake pad light is on too.
It is possible there is a bad seat belt receptacle that is causing the light. Also, the ground leads for the seat belts can be cleaned with a contact cleaner as they have been noted to have a bit of build up/corrosion over time that will trigger the airbag light. The seat has to be removed to change the receptacle, so you might as well clean up the grounds while you are in there if you go this route.
The airbag light will need to be reset after doing this with either a durametric or PIWIS.
+1 on the seat belt receptacle. classic 996 tt issue. replace and reset with a durametric or a porsche dealership will have to use their diagnostic tool ( pwisss whatever lol ).
its no big deal, just a hassle as you have to have the airbag light "reset" once the belt receptacle is changed out. many of us will have had that issue, i know i have
another +1 on the brake pads. change them before you damage either the sensor ( NBD ) or the rotors! very Big deal by comparison !
I think I'd be concerned the owner didn't tell you about this prior to your flight. Was it fully inspected, PPI, by that dealer or just this one issue investigated? Obviously this was known about with enough lead time to get a note from the dealer...
It was the seatbelt receptacle! Its perfect now. Thanks for your help! Also new pads and new rotors. Perfect car now! Wow!
25 months later hah! nice follow up, always good to know the resolution however belatedly lol
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-20-2015 02:37 PM
PelicanParts.com
991 Turbo Vendor Classifieds
08-20-2015 02:27 PM
Walorus
08-18-2015 01:39 PM
