help with #16 check valve
Old 07-04-2015, 01:06 AM
007-911's Avatar
007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of
Hello guys,
I did a boost pressure test today and found a few small leaks but found a huge leak with the #16 check valve. Basically, as I pressurised the system and I had a ton of air coming out of the drivers side inlet pipe connector before the turbo.
I did some research and found that the #16 check valve often fails. I also read that the limit of the OEM unit is 18psi. Thus, some people use a Mitsubishi check valve but I don't see any part numbers. Is there a better alternative to the OEM #16 check valve?
Vince
Old 07-04-2015, 03:24 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
Originally Posted by 007-911
Hello guys,
Vince
boost leak into driverside inlet plenum....maybe your check valve at the intake tb plenum is def....(on the top of the intake tb plenum)
Old 07-04-2015, 05:28 AM
'02996ttx50's Avatar
^1 yeah, i swore after yesterday and intmd8"s continuing issue, i'd never mention that little bastard of a valve again but here we are again. but it'll bite ya. 20 dollar plastic part. it cracks whether known or not. creates an intake ( duh ) system leak and/or boost issues. hard to isolate without a pressure test and can often frustrate until found to be bad.
Old 07-04-2015, 08:07 AM
007-911's Avatar
Thanks for the reply guys. I did identify that the check valve is bad by doing a pressure test. However, I would like to know if there are alternative check valves we can use that won't easily fail like the oem units.
Old 07-04-2015, 04:18 PM
i wouldn't think there was a choice but just stay with oem. they don't easily fail. mine lasted 10 years.
Old 07-08-2015, 07:22 AM
007-911's Avatar
Pulled the #16 check valve and found a leak by the FPR. The #16 was totally blown.
Blown #16 check valve
Old 07-08-2015, 08:04 AM
hah maybe now i can quit jabbering about #16! oh wait..
i betcha lots of folks with hairline cracks wondering, wtf?! wha happened to my boost! good call. nothing like a successful pressure test!
Old 07-08-2015, 02:40 PM
007-911's Avatar
I'm glad Markski got on me about doing that. Can't wait to see how the car is going to run now.
Old 07-08-2015, 02:44 PM
mine = night vs day. really.. no hype.
cant even imagine how long it was an infinitesimally small crack.. at first!
Old 07-08-2015, 03:17 PM
there you Vince... now your a believer that these cars have all sort of leaks...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 07-08-2015, 05:08 PM
BLKMGK's Avatar
What are the specs on the valve? Any reason why a better replacement can't be found?
Old 07-08-2015, 06:05 PM
hey maybe we could talk ipd mike into it? gotta be at least 300 a year in it lol ( sorry ).
seriously tho... I've never heard of an option, its too cheap but not worth making an alternate is my guess.
Old 07-09-2015, 08:31 AM
007-911's Avatar
Yeah, I don't see anyone really making a killing on these. However, finding the specs would be nice because we might be able to find an existing alternative.
Old 07-09-2015, 12:15 PM
turboGarrett's Avatar
turboGarrett is a splendid one to beholdturboGarrett is a splendid one to beholdturboGarrett is a splendid one to beholdturboGarrett is a splendid one to beholdturboGarrett is a splendid one to beholdturboGarrett is a splendid one to behold
I had looked into this in the past, ended up with a stock check valve. I believe these check valves would work http://www.maperformance.com/kracka-...acuum-kit.html
Double check the size and that they would flow the same direction.
Old 07-09-2015, 05:12 PM
BLKMGK's Avatar
McMaster-carr has some check valves that might also work. I need to leak test my car, if I find a dead valve I may experiment some
Quick Reply: help with #16 check valve
