Can Cobb unit help with door lock sensors?
I've got a situation where my central locking mechanism is doing the double beep upon lock, and occasionally on bumps the car will double beep while I'm driving.
I've done a bit of research and came to the conclusion that its likely one of the door latch sensors going bad, or the center console switch going bad, or the hood or trunk sensor, or the interior motion sensor.
Whew, that's a lot of potential sensors!
I then ran across that the durametric cable could scan to tell you which sensor was bad? That sounds much better than blindly replacing sensors. I then had the idea, maybe the Cobb unit could also read these codes? Because I wanted to eventually get one anyway to do a tune. Would be a great opportunity to justify to myself actually buying one to fix the horribly annoying double horn beeps my car does while I'm driving.
So, does anyone know if it would be able to read these codes like the durametric? My other option is to just buy a durametric cable to figure this out, but Id hate to buy one if when I buy a Cobb it will render it redundant.
PenguiN
09-15-2015 11:44 AM
LiquidElephant
08-27-2015 06:17 PM
riozilla
08-21-2015 11:34 PM
